U4200 Chip
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    U4200 Chip
    Hey guys anyone know where I can find a U4200 chip online for a MacBook Pro 15" A1707 (it is the Berkelium)
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: U4200 Chip
    I cant even seem to find out what this chip is called online as well
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Re: U4200 Chip
      Scratch that found it under 338S00193-A1
      sigpic
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • czacha414
        please help me identify macbook a1707 chip
        by czacha414
        Macbook A1707 - Guys, please help newbie confirm if chip on picture is a bios one?
        01-20-2025, 03:39 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • leonemax81
        Macbook a1707 820-00281 Battery no Power
        by leonemax81
        Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
        08-23-2024, 09:24 AM
