HP 820 G3 Absolute Persistence Module
  • yodafett
    • Jun 2020
    • 5
    Hi, It's been a while since I've messed with this laptop so my memory may not be 100% correct,
    Current Absolute settings are listed bellow.
    "Absolute Persistence Module Current State
    Activation Status: Inactive
    Absolute Persistence Module Permanent Disable: No"
    I would like to be ride of the Absolute all together if possible or at least be able to change " Permanent Disable to "Yes". Am I correct in thinking that "Permanent Disable No" means that it can be activated remotely at any time?
    In my first attempt I believe I flashed both the Winbound 25Q128FVPQ that's located next to the memory slots and also the 25Q64FVIQ that's located around the same area but on the under side of the board.
    Every time I would boot after flashing the system would inter a bios recovery mode and automatically reload the original bios, any idea what I was doing wrong? Or if it's even possible to do with a bios flash? Thanks.
  • saygi
    Lenovo ThinkPad T14s Gen2 Disable Absolute Persistence Module
    by saygi
    Hello, everyone.
    I've brought this laptop of gumtree it was sold under 'spare or parts' the only issue with the laptop was it tends to heat up after 2-3 hours and decrease in performance.
    because it did not come with a hdd I could not test it there, so I've installed a hdd and put windows 10 on it, I've used it for 5 hours and it did not heat up or decrease in performance however it turned off and displayed a message saying this laptop is disabled. I couldn't enter bios or boot windows at all. so I removed the hdd and reinstalled windows again and the message is...
    11-19-2023, 06:30 AM
  • berrylinx
    Dell Latitude 7400 2-in-1 bios with absolute persistence lock
    by berrylinx
    Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
    Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
    Thank You....
    09-15-2025, 03:02 PM
  • santoslao
    Precision 3591 Absolute disable
    by santoslao
    Can someone help disable Absolute on this machine?
    Dell Precision 3591
    ST: HCW3M44...
    08-11-2025, 01:53 PM
  • Rapha Alves da Silva
    Lenovo E14 Gen2 Absolute Disable
    by Rapha Alves da Silva
    Please, Someone could help me to disable absolute from this bios file
    Lenovo e14 Gen2 20TB
    NM-D011
    Serial PE09A2FM...
    06-30-2025, 02:32 PM
  • Mr.Ultimate
    Dell Precision 5540 - Absolute / Computrace permanently enabled. Need bios fix to disable
    by Mr.Ultimate
    Hi, I have Dell precision 5540 laptop from old workplace,decommissioned old stock. its a good spec laptop i9-9880H etc, so I decided to keep it and use it for personal purposes.
    I was checking bios settings and I found that Absolute (Computrace) is permanently enabled/activated, and field is grayed out, unable to change it to disabled/deactivated state. The laptop status is clean, absolute has no any warnings or messages booting pre-bios pre-OS or post booting, while using laptop, im just not feeling safe having absolute permanently enabled having backdoor on a bios level enabled to my...
    08-06-2024, 05:24 AM
