Lenovo G510 turn off when want a boot
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hello
    A device
    I have a Lenovo G510 la-9641p
    The problem with the device is that it shuts down as soon as it is booted, which means that when it tries to boot the hard disk or boot the flash, it shuts down quickly, but it does not shut down at all in the BIOS.
    I programmed the BIOS
    I programmed I / O
    I tested the motherboard outside the device, it still turns off, but it does not turn off in the system BIOS.
    I tested it on an optical drive, flash drive, and network, but it turned off as soon as it wanted to boot.
    LENOVO G510
    VIWGQ GS LA-9641P REV 1.0
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Re: Lenovo G510 turn off when want a boot
    NOTE:
    now i tested with battery system boot up and work but with only adaptor same problem
    system want to boot flash or hdd going off.
    i try with another adaptor but turn off
    • mon2
      • 14684
      BIOS -> Load SAFE defaults -> save and see if this helps.
      • khelane
        • Apr 2015
        • 172
        • xxxx
        tnx try it but no work
        with a battery good work but with a adaptor when come to boot device go off
        • Sametbey
          • Jan 2021
          • 229
          • Turkey
          the screen could be a chip error. it can work with lower resolution with battery. try canceling the vga chip feed coil PL802 and 803.
          I'm not happy to be so strong. because it's not humanly
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Could be fault in charging circuit as well.
            • khelane
              • Apr 2015
              • 172
              • xxxx
              tnx repalce ic charge and work
              tnxx fo all
              • Sephir0th
                • Oct 2020
                • 1289
                Thanks for Sharing the solution and of course thanks to mcplslg123 for pointing to the right direction.
                FairRepair on YouTube
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  We all learn from each other. I appreciate your devotion to our forum.
                  • Luke Anders
                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                    by Luke Anders
                    A few details about the laptop itself:
                    Name: Lenovo Legion 5
                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                    BIOS Version: GKCN60WW
                    EC Version: GKEC65WW
                    Serial Number: PF39AQ7Z
                    Board Model: NM-D562 Rev 3.0
                    RAM: 16GB Installed, DDR4 (brand new)
                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                    I bought this laptop recently from eBay as a faulty device....
                    10-12-2024, 05:13 AM
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • melvinvdb
                    Lenovo y520-15ikbm most of the time doesn't turn on
                    by melvinvdb
                    I've repaired a few laptops in my life but this time my own laptop died😂.
                    Funny enough this one is a bit tough on me.
                    It doesn't turn on (most of the time).
                    Model: Lenovo y520-15ikbm (NM-391).
                    The only way to make it turn on is:
                    1) unplug battery + charger + rtc (seems irrelevant)
                    2) wait a minute
                    3) plug battery/charger in
                    4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
                    5) when it turns on it also displays POST...
                    08-15-2024, 12:28 PM
                  • Max029
                    Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                    by Max029
                    I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                    I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                    TY,
                    08-18-2024, 08:28 PM
                  • q2v5
                    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                    by q2v5
                    Lenovo T480s
                    Model 20L8-S3TE00
                    Board ET481-U10
                    Chip MX25L12873F
                    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                    08-15-2024, 10:40 PM
