iPhone X battery issue
  • Nash99
    • Apr 2021
    • 51
    • South Africa
    Hi Everyone
    I have an iPhone X that is doing something very weird.
    The iPhone will show the actual battery percentage and then restart and show 0%. Then after a while it will show the actual battery percentage (without restarting). Then the process will repeat itself.
    Anyone know what is causing this?
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • code share
    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
    by code share
    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
    Here's what I've tried so far:
    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
    • Booted successfully on AC power only with the battery disconnected
    • Visual inspection of the battery — no swelling, burn marks, or connector damage
    • Battery
    04-21-2025, 12:50 PM
  • huzo
    HP ELITE X2 1013 G3 weird battery issue
    by huzo
    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
    01-31-2025, 12:09 AM
  • danielsak
    Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
    by danielsak
    Hello, I have issue with Dell Inspiron 3542.
    Motherboard marking:
    Code:
    PWB FX3MC REV: A00
    The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
    1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
    1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
    10-11-2024, 04:36 PM
