820-000138, no external image
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    Hello!
    I have a 2015 15" (IGPU-only, NO DGPU), 820-00138..
    Has a broken screen with some liquid spill around U7310 pin 11 to 14, C7316, C7319, C7318 and C7317..
    All caps replaced and U7310 chip cleaned and resoldered properly..
    The computer POSTs now, I try another screen and it shows image successfully...
    But for some reason it's not showing an image externally.. I tried the HDMI output and both of the thunderbolts outputs with no luck..
    Honestly I have no idea where to start now and a bit lost..
    Help?
    Thanks!
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    Re: 820-000138, no external image
    [ SOLVED ]
    Apparently all three ports were really really dirty and none of them were communicating properly.
    • Sephir0th
      • Oct 2020
      • 1289
      Thanks for Sharing the solution!
      FairRepair on YouTube
      • Coguar
        HP ProOne 23.8 inch G9 ALL-in-One Desktop PC - Working when plugged to an external monitor, no image otherwise
        by Coguar
        In the device manager there is no built-in display located. The Intel UHD Graphics are displayed and only the external display is visible. The AiO turns on and works but is only showing a black screen on the monitor.
        I checked the voltage on the backlight connector and it reads ~20V. I tried reseating the LVDS and Backlight connector, yet the image still does not show.
        Does anyone have ideas whether or not this is a BIOS related issue? The only visible log in the BIOS logs is that the firmware was updated around a month ago.
        We already tried to fix it by resetting the...
        06-23-2025, 07:14 AM
      • Madoy104
        Macbook Pro A1989 - No image, working fine with external monitor
        by Madoy104
        I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
        08-15-2024, 10:01 AM
      • larrysito111
        dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
        by larrysito111
        got here a liquid damaged alienware
        the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
        so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
        so with the usb-c external monitor is getting to bios and OS
        otherwise not
        so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
        but still not the internal monitor
        (tested 3V and 5V going to the...
        06-12-2025, 04:16 PM
      • f-bone
        dell la-b843p image only on external
        by f-bone
        Hi guys,
        this one seems to work except that there is no image on LCD, only on external via HDMI. I have flashed the bios with a cleanME one and measured voltages at GPU (0.9V) and LVDS connector (LCDVDD_LCD is 19V and DCBATOUT_LCD is 3.3V). I can see the LCD going black after power on but no image. I shed some light with a torch but there is no image or activity at EDP_TX0/1 using the oscilloscope. I also tried a different panel.
        any ideas are welcome.
        br,
        george
        12-19-2022, 06:59 AM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
