IPad activation lock
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1221
    • France
    Re: IPad activation lock
    Originally posted by davg
    another option is to buy (on aliexp e..y ) new kit of serial number bluetooth and wifi mac address and change it with serial cable in purple mode with tools like magiccfg
    since you have a ipad pro 1 is still not supported, so you have to desolder the nand and change those values reprogramming it.
    Where can I learn to do this. Does a 4th gen need desoldering[/QUOTE]
    https://www.youtube.com/watch?v=PIm5Zs-_VAU
    not tested on ipad 4 for me
    works on another models
    • davg
      • Sep 2008
      • 536
      In your case, you just need to change the serial number. either unsolder the nand and reprogram it or otherwise with a purple cable[/QUOTE]
      I'm interested in learning how do do this can you recommend some reading know how?
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1221
        • France
        https://www.youtube.com/watch?v=l28bHNifuCw
        lots of video on youtube just tape purple mode
        • davg
          • Sep 2008
          • 536
          seems like only works on wifi models mine is a1459 wifi plus cellular
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1221
            • France
            Model A1459 iPad Pro Wifi only.
            Look on google bypass cellular
            remove R1204
            • davg
              • Sep 2008
              • 536
              What equipment would I need to do this
              • davg
                • Sep 2008
                • 536
                There are a lot of sources out there who say they can provide the unlocking service for a fee? just wondering how legit they are and if anyone has tried any of these services with any success. I am reading that Apple has blocked a lot of the free services including jailbreaking?
                  • 20665
                  The method at post #25 is the best way,ive done it.It will then only work as a wifi model.If you can`t remove the resistor with your soldering iron just flick it off with a blade or small driver.Connect to itunes and restore (wifi model) firmware
                  • davg
                    • Sep 2008
                    • 536
                    So any thoughts on the icloud unlocking websites like this one <LINK REMOVED>
                    Are they legit? I am looking for the easy method since my technical skill are limited
                      • 20665
                      Never used any of those personally,there`s a lot of them around and all dubious.
                      • davg
                        • Sep 2008
                        • 536
                        Once you removed these 3 resisters did you have to change the SI#? when connected to itunes and restore do it find wifi model firmware automatically? The video is showing connected to a software 3uTool is that required?
