820-000923 Critical Update
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    Hope you guys all doing good.
    This case has been a pickle for me.
    Issue: liquid was spilled around the U3200 area and mainly around U4200.
    Originally this computer came in for a no power issue; this case is pretty old I can't remember what I changed and it turned on successfully.
    Now after the computer POSTed successfully; it asks for the magical critical update.. I replaced some caps and resistors and round U4200 such as R4203, C4234, C4235.. they were looking shady.. I removed U4200 and reballed it, same issue..
    I ordered a right wing from AliExpress and extracted U4200, reballed and installed with the same issue..
    I have opened the schematics of this puppy (U4200, berkelium chip) but I cannot understand sh*t! *giggle*
    What else could it be?
    PP3V3_S4_SOC_PMU is 1.1v
  • eclectric
    Sony Bravia KDL-70W850B T-CON board / software update issue
    by eclectric
    Hi, I'm hoping someone can help me with this issue before I give up on this TV.
    In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
    Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
    I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
    05-23-2022, 01:25 AM
  • iMuhtaseb
    A1706 2017 critical update
    by iMuhtaseb
    this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
    we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
    One weird symptom is it takes too long to power on and show the Apple logo for some reason..
    I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
    08-13-2024, 08:41 AM
  • T4-BR
    T470S - TPM issue since TPM/BIOS update from Windows Update
    by T4-BR
    Many thanks for the high quality ressources available on your website.
    I'm currently facing some issues with my T470S:
    - I sat a Supervisor Password using special chars which was causing issues
    - Access to BIOS was locked but I was still able to use my PC
    2 weeks ago, I got an update of BIOS/TPM from Windows Update.
    Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
    Computer restarted one more time and I got the prompt for typing Bitlocker...
    09-26-2024, 02:50 AM
  • ahmypc
    Microsoft Surface Pro 4 Bios Update Issue
    by ahmypc
    The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
    09-21-2023, 02:14 AM
  • PITERPENY
    Macbook A1707 820-00281 critical update
    by PITERPENY
    Hello! Does anyone know what the problem might be? I've already tried everything and can't get past this window!
    02-14-2025, 05:03 PM
