dell n7010 uma convert
  • didouche1200
    • Oct 2016
    • 367
    • 82679911441
    any help for convert dell n7010 quanta um9b to uma or bordview
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
  • pleomax1110
    Quanta DA0R05MB8D2 Rev. D (Quanta R05 / Dell 14z-N411z) schematics needed
    by pleomax1110
    Hello, everyone!
    I need schematics of this board:
    Model: Dell Inspiron 14z-N411z
    Board No: DA0R05MB8D2
    REV: D
    Quanta project: R05
    I have already seen the file ''quanta R02_UMA.pdf'' in this thread:
    https://www.badcaps.net/forum/showth...dell+14z-n411z
    but it is differ from R05_UMA and it can't help me in my case.
    The main problem of the laptop is as follows:
    LED backlight is absent in the screen and appropriate 36's contact of the LVDS 40pin 1ch connector is shorted...
    10-21-2022, 01:56 PM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
