iPhone XS not charging
  • Nash99
    • Apr 2021
    • 51
    • South Africa
    Re: iPhone XS not charging
    Can you use an iPhone X logic board to charge an iPhone XS battery?
    • mon2
      • 14003
      According to this picture, yes. Same connector for a number of models:
      https://a.aliexpress.com/_mKoXgqd
      Very bottom battery connector.
      Also, use google chrome to access Ben's website. It will then allow to auto-translate to English.
      • Nash99
        • Apr 2021
        • 51
        • South Africa
        Yes, I also saw that and thought it did. However, it does not seem to want to charge the iPhone XS battery, it only displays as 1% on the screen. However, when I plugged the iPhone X battery back in, it charges like normal.
        I have tried both iPhone XS batteries
        • mon2
          • 14003
          Now that is interesting. Perhaps your XS battery is bad. Known to happen.
          Is it the Apple original or 3rd party battery ?
          If you leave out the (defective) battery on your XS - any different results when docking the lightning connector to your charger or host computer system ?
          Since XS and X batteries share the same connector - does the X battery work on your phone ok ? Any chance your XS phone is able to charge the X battery?
          • Nash99
            • Apr 2021
            • 51
            • South Africa
            So one battery is an Apple battery and the other is a third party.
            If I remove the battery, the XS just turns off.
            The X battery does work on the XS but it does not charge it.
            I managed to charge the XS battery to 3% and the XS turned on find. I connected it to a MacBook and windows computer, however, nothing happened.
            Do you think the best chip to replace first is the hydra or the charger IC
            • mon2
              • 14003
              Hyrda first since the phone should have been detected through a known good Lightning cable when it is docked to the macbook or any other computer system.
              There is no USB activity so seems to indicate a fault in the Hydra component.
              While you are sourcing the Hydra chip, it should be possible to buy the charger IC from the same supplier at under $5 USD. Aliexpress has them all.
              Hydra IC = CBTL1612A1 @ U6300 (as shown in the XS schematics).
              Charger IC = SN2600B0 @ U3300
              • Nash99
                • Apr 2021
                • 51
                • South Africa
                #27
                Thank you for that information. So do you suggest that I replace both chips?
                If the hydra chip is damaged, does that mean the charger IC chip also gets damaged?
                Also do I have to buy a heating plate to separate the boards or can I use a heat gun?
                I am trying to avoid buying internationally because our customs here is on backlog for 6 months.
                I used the X battery in the XS and managed to find an iOS 15 beta 2 profile and updated my iPhone to it. However, my phone still did not charge.
                • mon2
                  • 14003
                  Hi.
                  1) No, the Hydra is a separate IC and function than the charger. It is very possible that the charger IC will work properly after the Hydra is replaced. Best to search around on the topic and youtube videos but given that USB does not work at all, I would start with the Hydra. Very sad to know that this happened after the IOS update. Concerns are that did the excessive heating cause some joints to come undone and raising this issue ?
                  You could try to reheat the Hydra IC area with low pressure but enough heat to reflow the solder joints.
                  2) From our knowledge - yes you need the jig made for this purpose and that is to properly desolder the many joints on the 2 PCBs. I think it is too risky to do this operation without it. Consider to contact Sunshine and/or Qianli in China. They are very well known firms in China and ask if they have stocking agents in S. Africa. Likely that they do.
                  3) Before proceeding, are you able to perhaps restore this phone to an older (working) version of the IOS? Perhaps that will help these issues.
                  It will suck if you truly are facing hardware issues but all due to this flaky IOS update. Given that it takes s/w to make or break the operation of the USB interconnect and the charging circuits, perhaps you are stuck all due to the latest IOS update ?
                  Personally we have not come across this case and even told my son to avoid the latest update for his iphone 12 till the dust settles.
                  Please check around and even chat with someone who is local or Ben in Germany for advice before moving forward. At the very least they can offer what they will do for the repair so we can all know that we are on the proper track.
                  Are you confident that your USB charging cable was replaced ok? That is of course another factor. The charger can remain non-working but the phone should have been detected by any host PC with a good lightning cable.
                  • Nash99
                    • Apr 2021
                    • 51
                    • South Africa
                    #29
                    Hi Mon2
                    1) Yes, I was thinking the same thing. I think when I separate the board and put it under the microscope, I will have to check every part.
                    Yes, I can try that because maybe with the heat one of the solder joints cracked.
                    2) I saw some guy selling it for $145 in my country but that is way out my budget.
                    3) Because I cannot connect my phone to a laptop and restore it using a IPSW, I have to use a profile to do it. The only this is that I cannot find any profiles for before iOS 14.6.
                    4) It really does suck, a simple update can break a very expensive phone. If you can find a profile for an iOS before 14.6 it will really help.
                    Yes, it is definitely best not to update any iPhone at the moment. When I was updating my phone to iOS 15 beta 2, it got extremely hot again.
                    Yes, the USB charger is fine. I have used many Apple and 3rd party ones. The funny thing is that when I plug my iPhone in, it starts up without me having to press any buttons. So it knows I plugged it in, it just doesn't charge.
                    • mon2
                      • 14003
                      Wait. If this occurs, then the usb is working as the phone turns on upon attaching to the adapter. Can you run iTunes and see if the phone is detected when mated to a computer?
                      Proper tools are a must to service these delicate designs. I recall another really good guy in Spain who has tons of youtube repair videos. Contact him to ask for a quote on this repair. He was the one who blew the whistle on Apple on the audio chip losing contact from too much heat and causing the boot loop issue. Let me see if I can find his details.
                      • mon2
                        • 14003
                        Try the first suggestion posted here:
                        https://discussions.apple.com/thread/252810204
                        • Nash99
                          • Apr 2021
                          • 51
                          • South Africa
                          #32
                          No it is not being picked up by either my MacBook or PC.
                          I see that a lot of people are having the same problem after the update. I do not know why Apple released it so quickly.
                          I tried the fix by TDarby719 but it did not work.
                          Yes, if you can try get the guy from Spain contact detail, it will really help.
                          Do you think I should wait for an update before attempting any repair?
                          • mon2
                            • 14003
                            Ok. Found him but he is in the UK. He is very talented and discovered the audio ic boot loop issue and fixed it.
                            Highly recommend to at least contact him or Ben for advice on this case.
                            https://youtube.com/user/THEiMAN111
                            https://www.logicboardrepair.london/
                            • Nash99
                              • Apr 2021
                              • 51
                              • South Africa
                              #34
                              I sent him a message and I am not waiting for a reply.
                              I also looked at Ben's website and it costs $360 to replace the Hydra. It is cheaper to purchase a new logic board. I can email him and see if he can offer any advise.
                                • 20665
                                have you tried putting the phone into recovery mode
                                • Nash99
                                  • Apr 2021
                                  • 51
                                  • South Africa
                                  #36
                                  Yes I have, however, since it is not detected by the computer it does not go into recovery mode
                                  • mon2
                                    • 14003
                                    OMG...$360 to replace Hydra??? Whoa. Keep checking.
                                    • Nash99
                                      • Apr 2021
                                      • 51
                                      • South Africa
                                      #38
                                      With the jig price it is cheaper and easier to buy a new logic board. If I did not need a jig, I would have just purchased the chip locally and replaced it for free.
                                      If I can get the cheapest jig, it will make it a lot easier. The only problem with getting it internationally is that our customs are useless in SA.
                                      I need a sponsor 😂
                                      • mon2
                                        • 14003
                                        Can you download the update using your data plan rather than the USB cable?
                                        See the suggestion here:
                                        https://drfone.wondershare.com/ios-1...tion%20instead.
                                        Fix # 5.
                                        • Nash99
                                          • Apr 2021
                                          • 51
                                          • South Africa
                                          #40
                                          When I do that it says "iOS is up to date"
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                            Common SPI bios chip programming Questions and Answers
                                            by SMDFlea
                                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                            A: If you can`t read from it how do you expect to write to it ?.
                                            Q: Why is my bios chip unreadable ?.
                                            A: The programmer is faulty or has a worn or broken zif socket.
                                            The USB cable is frayed,connector pins worn or some other physical damage.
                                            Not enough amperage or voltage to power the programmer properly.
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
                                          • Julian Bailey
                                            HP ProBook 445 G8 Battery not charging
                                            by Julian Bailey
                                            Hi all
                                            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                            I have gone around the board with a MM and cant find anything
                                            Windows shows the battery fine,...
                                            10-11-2024, 10:34 AM
                                          • Troystain
                                            Help EZP2023+ updated chip database for w25q256jveq?
                                            by Troystain
                                            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                            I need to add w25q256jveq chip but I do not know what data should I type.
                                            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                            11-25-2024, 12:53 AM
