V5we2 la-9531p
  • pippo_one
    • Aug 2010
    • 127
    • Vicenza
    V5we2 la-9531p
    Hi everyone, I have a mainb V5WE2 LA-9531P that has this defect:
    if I install 2gb of ram, the monitor turns on I can enter the bios, if I install a 4gb ram I have no video signal and consequently I cannot enter the bios
    if I install both ... in the bios I am only recognized 2 gb ....
    can someone please help me?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: V5we2 la-9531p
    DDR3L right?
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • BMCappelletti
      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
      by BMCappelletti
      Hi everyone.
      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
      02-18-2025, 12:22 PM
    • alfredposadas09
      cant enter recovery mode lenovo c13 yoga chromebook
      by alfredposadas09
      cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
      11-09-2024, 10:09 AM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • tommy97
      ASUS FA507R - BLOD, cannot install windows
      by tommy97
      I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
      I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
      08-22-2025, 07:55 AM
