Dell XPS M170 inverter or LCD?
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    I have a new to me Dell XPS M170 computer, upon booting up from cold the screen has a pink hue to it but goes away in around 10 seconds and will work anywhere from 2-10 minutes before flicking and going off. alot of times I can shut the lid and the screen will come back from sleep only to go off shortly after.
    The duration of the screen staying on seems to depend on how long its off. also I can of course still see the screen if a flashlight is pointed on it. Do you guys think its an inverter causing the problem or the CFL bulbs going bad, it is noticeably dimmer then other dell 17 inch laptops I have had even at full brightness.
    Also wanted to add I re seated the inverter and LCD cables on the screen and to the graphics card.
    Any help appreciated.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dell XPS M170 inverter or LCD?
    Most likely aged CCFL.
    • BigTroll
      • Sep 2010
      • 1317
      • LAMBDA SOND
      Thank you I will have to look into getting another screen
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • Swedishpower
        Dell G3 15 3500 black screen
        by Swedishpower
        Hello
        I have search everywhere for a solution for my problem, but cant find it anywhere.
        When I was away to trow some garbage i always look in the electronic bin.
        and this time i find a laptop.
        Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
        the lamp for charmig is white.
        Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
        but no Dell logo.
        I tryed with a hdmi cable to another screen, still black.
        I started to search solution and tryed...
        07-06-2025, 06:18 AM
      • jake-b
        dell e6540 boots to black screen (no dell logo)
        by jake-b
        good morning all,
        i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
        01-08-2024, 10:29 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
