820-01814-01 Macbook Pro A1990 with short
  • carlucci
    • Aug 2012
    • 50
    • Moçambique
    Hi all.
    I have here a Macbook Pro that already as been in another tech and came with a short in ppbus_g3h.
    the board model is 820-01814-01, I already have the schematic and boardview.
    A need guidance here, like where to start cheking.
    Thank you.
  • mon2
    • Dec 2019
    • 14106
    Re: 820-01814-01 Macbook Pro A1990 with short
    hi.
    1) PPBUS_G3H is created by U7000.
    2) Remove all power. Meter in ohms mode (resistance). Check the resistance to ground on F7000 (fuse), pin # 2. Value in ohms ?
    Assuming the reading is low - then you have a short on this rail or a bad cap which will show similar results.
    3) Remove F7000 & F7001 (if present) and repeat the reading on F7000, pin # 2. Value in ohms ?
    4) With F7000 & F7001 OFF the logic board, power up and check if you see the PPBUS_G3H rail at the proper value @ F7000 pad, pin # 1 ?
    This test is without F7000 installed.
    Just wanting to confirm that U7000 and local mosfets are working ok.
    • carlucci
      • Aug 2012
      • 50
      • Moçambique
      Hi.
      Resistance to ground on F7000 pin #2 is 00.3 ohms
      After removing F7000 & F7001 pin 2# is 00.3 ohms
      Powering the board gives me 12.23v in F7000 pad in pin1.
      • mon2
        • Dec 2019
        • 14106
        So you definitely have a short on this rail. Good to see the PPBUS_G3H working ok.
        1) Any liquid damage ? Any corrosion ? Any parts that look like they have been played with?
        2) You either have a hacked up (bad soldering) logic board where there are solder shorts and causing this issue. Or you may have a bad cap that is causing this event.
        Do not recommend injecting of a power supply from your lab till we know more about this logic board.
        Search around where you may find where the last tech was - that area needs to be carefully reviewed for the short. If nothing is found, only then should you consider to inject an external voltage rail of perhaps 1v0 and check the current draw. The idea is that the shorted part will heat up and self destruct - hoping it will be a bad cap.
        As noted above, search for bad soldered parts first from the last tech.
        For assistance, remove fuse @ F8400. Just for now. Does this short disappear ? This fuse is linked to the backlight regulator.
        If the short does not get removed, solder fuse F8400 back onto the logic board.
        More ideas to try (to locate the PPBUS_G3H short):
        1) remove the trackpad cable or remove fuse F6700. Check for the short condition again.
        2) Assuming that the last tech was not a hack and did not short out pads with their soldering...review each polarized cap that is mated with the PPBUS_G3H rail. In the PDF schematic, search for "PPBUS_G3H". Once you find a block of bulk caps, review each for possible visible damage / color change on the body of the part. If you suspect it, carefully remove the bulk cap.
        Post back on the condition of your logic board and hope you can use an external power supply to inject power and alcohol to hunt down the bad cap.
        Would you have an external power supply and alcohol? We have used this method to fix a number of bad cap logic boards very quickly.
        • carlucci
          • Aug 2012
          • 50
          • Moçambique
          Hi, yes I have power supply and iso alcohol. Tomorrow I will follow your tips and will send you the feedback later. Thank you very much.
          • carlucci
            • Aug 2012
            • 50
            • Moçambique
            I forgot to tell you, after I remove F7000 and F7001 I saw "light red" spots in the board, so, liquid damage areas.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              post picture of red dot zone.
              • carlucci
                • Aug 2012
                • 50
                • Moçambique
                pictures attached.
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  red spot looks like ripped of component, while green spot looks like desoldered component.
                  remove fuse f7001 f7002 and solder one wire to pin 2. use lab psu and try with 1 volt and see if something get hot.
                    • 20781
                    The red spot i think is the moisture sticker.Its white,then turns red with liquid damage,invalidating any warranty. When he said "light red" spots in the board" he might have meant sparks ? don`t know .
                    • carlucci
                      • Aug 2012
                      • 50
                      • Moçambique
                      Yes it's the sticker that turn's red with liquid damage. Tomorrow I will give you the feedback of your tips, Thank you very much.
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        yes i was meaning red and green zone in my modified pictures
                        1 red and one green for esch side of the board
                        • carlucci
                          • Aug 2012
                          • 50
                          • Moçambique
                          Hi Guys! sorry my delay. I'm away and will be back in first week of july, please do not close this thread. Thank you.
                          • carlucci
                            • Aug 2012
                            • 50
                            • Moçambique
                            Hello guys, for the sake of respect for everyone, I owe an explanation, I could not return to this subject because in the meantime I was hospitalized with COVID and I am still recovering from all this, I predict to return to active duty in November. Thank you.
                            • Patrick501
                              MacBook A1990 PPBUS_HS_CPU short
                              by Patrick501
                              I have a A1990 which had a blown inductor next to the display connector. There was no short at this spot, so I replaced it.
                              I noticed that the big coils above the GPU/CPU (PPVCORE) had a pretty low resistance (2.2Ohms). I already talked about this with mon2.
                              PPBUS_G3H, PPBUS_HS_CPU showed 1.8ohm to gnd. So I removed the R5400 to seperate the two rails. PPBUS_G3H is fine again but the short is unfortunately on PPBUS_HS_CPU. Sounds like a no fix to me.
                              Plus I can't find any particular spot which his heats up when I inject 1V@max2A
                              02-06-2025, 02:52 AM
                            • Stephen
                              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                              by Stephen
                              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                              02-06-2025, 12:03 PM
                            • sdogs
                              macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                              by sdogs
                              Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                              First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                              I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                              06-27-2025, 01:58 PM
                            • sdogs
                              by sdogs
                              06-27-2025, 11:26 AM
                            • Arshad alam4659
                              MACBOOK PRO A2141 SSD SHORT
                              by Arshad alam4659
                              I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
                              PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
                              Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
                              10-01-2024, 08:26 AM
