Macbook and BIOS battery
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    it seems that no Macbook uses BIOS battery that is almost always present in PC laptops. I guess that Macbook battery is also used for that purpose.
    I wonder why BIOS battery is needed in most PC laptops and why Macbook is different.
    Thank you!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook and BIOS battery
    Laptops with non-removable batteries don't use a coin cell battery, RTC circuit is powered from main battery pack. Laptops with removable batteries do use a coin cell battery, RTC circuit is powered from coin cell battery when main battery pack is removed.
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Hello piernov, thank you for your reply. However I'm not sure this is the reason. Today I have upgraded HDD to SSD on HP x360 m3 2in1 and I noticed Bios battery even if battery is closed inside the case.
      Please have a look at this: https://youtu.be/jjFFoWidcm8
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        HP just tends to use separate batteries. Otherwise piernov is correct.
        There's no difference between PC and Mac when talking about bios batteries. Some use, some don't and that's how it is. When a laptop has user removable battery, it has a bios battery.
        • brispuss
          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
          by brispuss
          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
          12-28-2022, 02:58 AM
        • razenxd
          How can I charge that battery pack?
          by razenxd
          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
          Now, I have noticed a few things.
          The "dead" battery, while connected to charger and NOT Charging will...
          12-05-2024, 06:11 AM
          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
          by sam_sam_sam
          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
          So I have put them on the battery testing machine to drain each battery cell down to...
          09-04-2022, 04:45 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
          by sam_sam_sam
          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
          I bought this from an eBay seller but unfortunately they only had one
          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
          I bought three of from them to also make battery packs with this output power limit in mind
          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
          04-23-2025, 05:50 AM
