Dell Precision 3510 completely dead
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    Got a Dell Precision 3510 dead with burnt SIC530 mosfet.
    Some copper traces are gone from the heat, 6, 7 and 8 pin are the same (Vin) and this is the easy part but it also lost pin 3 (N.C) and i'm not sure if and where i can bridge it.
    I'm not sure if it's worth it our time that's why i ask you first before i order the mosfet.
    Please check schematics and datasheet of SIC530 and let me know.
    Thank you in advance
    schematic https://www.badcaps.net/forum/showth...04#post1053304
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: Dell Precision 3510 completely dead
    Hoping it did not fry your CPU, you could attempt to repair it. I would also replace the other components connected to it. Pin 3 is NC (Not connected), just leave it as is. Make sure to clean the soot properly before soldering on new components.
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      Really? Now that's good luck.
      What other components you mean?
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        The resistors (4R7, etc) and capacitors etc.
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          How can i check if there is a shortcircuit that cause mosfet to burn?
          I think mosfet don't explode on their own, correct?
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            There are many reason as to why electronic components fail. MOSFET handle higher currents and are more likely to fail than components carrying signal (low power).
            In your case, the MOSFET (both high and low drive) and the driver itself is all in one chip. With the chip removed, measure resistance to ground on Vin (pin 6). VSHW (pin 8) will show a low resistance because of the CPU which is normal. You should measure resistance to ground on all pins actually.
            Replacing the surrounding components, especially the way the chip has failed, is good practice and as well as a precaution since you cannot be sure it did not sustain some form of damage which may not be immediately apparently.
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              Hello!
              You mean these that i marked in red (attachment)?
              I'll check resistance as soon i return to bench, meanwhile i order the MOSFET (5x just to be sure)
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                Yes. Also, although the other nearby capacitor and resistor looks OK, I would still replace them if possible.
                Check the tracks properly before soldering new parts to make sure they did not break/crack, etc.
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  Hello Spider!
                  Finally the MOSFET lot i ordered is here so i can proceed with this.
                  So the Vin has only 3Ω to ground and full continuity.
                  Should i proceed to rest measures or the problem is here?
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    VIN (pin 6) of PU602 you mean? You are measuring with the IC off, correct? If so, 3ohm is too low and is indicating a short on that line.
                    Remove PL602 and/or PJP601 if present and measure resistance to ground on both sides (pin 1 and pin 2 of PL602).
                    Report back your readings.
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      Yes pin 6, 7 and 8 (the same trace) of PU602, with burnt IC desoldered like in picture.
                      I can confirm left side of PL602/PJP601 (side of MOSFET) is shorted to ground.
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        6, 7 and 8 of PU602 are not the same. 7 is ground so short to ground here is obvious, pin 8 goes to CPU via PL603 and therefore low resistance is to be expected but pin 6 is VIN and should definitely not be low resistance.
                        Mosfet side (pin 2 of PL602) is around 3ohms, correct? What about pin 1?
                        • Andreasbest
                          • Aug 2014
                          • 1196
                          • Hellas ( Greece )
                          I measured according to datasheet but propably is reserved?
                          • Spider1211
                            • Oct 2019
                            • 532
                            • Mauritius
                            My bad, I was referring to schematic. What is the resistance on Pin 1 of PL602?
                            • Andreasbest
                              • Aug 2014
                              • 1196
                              • Hellas ( Greece )
                              pin1 15Ω
                              • Spider1211
                                • Oct 2019
                                • 532
                                • Mauritius
                                That's low. Just to confirm, you did remove PL602 and PJP601 yes?
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  Yes pl602 is removed (pjp601 under pl602 is not soldered at all, pure copper)
                                  • Spider1211
                                    • Oct 2019
                                    • 532
                                    • Mauritius
                                    Remove PJP603 (make sure you clean the pads properly) and measure resistance pin 1 of PL602 again.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      with pjp603 removed and cleaned 14.7Ω
                                      • Spider1211
                                        • Oct 2019
                                        • 532
                                        • Mauritius
                                        Something is pulling +PWR_SRC down. From the picture it seems the soot extends to QV1. Try removing it and see if that changes anything. Otherwise you need to check around for damage.
                                        Maybe try disconnecting +PWR_SRC jumpers on different power sections and see if that changes anything.
                                        There is also the issue of low resistance (3ohms as you mentioned) on pin 2 of PL602.
                                          DELL Precision 7071 Precision 7000 i5-9500 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 7071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 7071 boardview and Precision 7071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Precision T3420 Precision E3-1220V5 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3420 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3420 boardview and Precision T3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision 3620 Precision i3-6100 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3620 boardview and Precision 3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Precision T3620 Precision i7-6700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision 5820 Precision 5000 W-2235 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
