Bricked my M18X R2(LA-8321p)
  • Razor0601
    • May 2021
    • 34
    Hello, this is my first post and I hope you can understand me. Because my Englisch could be better.
    I have an old M18X R2 laying around for 1 Year. I bought it with (I think) a faulty Bios. The seller installed a GTX 1070. He said it works fine but he made a mistake and deactivated the iGPU. And after that the M18X never showed something on the screen. Whether an MXM GPU is installed or not. I tried several I7-3xxx CPU‘s. With one there is a 7 time beeping and with another there is 2x beeping. So I thought there is an BIOS Issue and I decided to do a Blindflash but couldn‘t fix it. After that I bought a CH341A programmer and wanted to flash the Bios. And I flashed the U15 BIOSchip. That is a 128kb file and I think I flashed the false one, because U1 is the Bios, right? At the first time after I flashed the U15 Chip nothing changes. So I tried a second time. Unfortunately I interchanged pin 1 and 5 and now I think I have a short because nothing happens when I push the power button. And I can hear a technical??? Noise from the ENE KB930 Chip.
    Can someone help me?
  • mkdj
    What should I do after having flashed a BIOS?
    by mkdj
    Dear all,
    I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
    Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
    09-09-2025, 09:45 AM
  • Loli Popu
    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 03:28 AM
  • Fr33man
    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
    by Fr33man
    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
    *Novo button power on
    *Disconnected internal battery...
    09-23-2024, 01:16 PM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • q2v5
    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
    by q2v5
    Lenovo T480s
    Model 20L8-S3TE00
    Board ET481-U10
    Chip MX25L12873F
    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
    08-15-2024, 10:40 PM
