Another 4730s HP laptop and some questions
  • pecrie
    • Nov 2011
    • 182
    Hi guys ,
    So , I have this 4730s laptop - Inv RAMONES (6050A2465501-MB-A02)
    When I got it , I checked for shorts and checked the resistance.I could not detect any shorts but it would not power up.
    So , I flashed the main and EC bios - and after that it would start normally.
    However , after several starts (at different times/days) I now notice that the DC jack led will sometimes blink continously.And then nothing happens
    There is no 3V & 5V -
    Sometimes the laptop will power up all by itself , as soon as I plug in the power supply.Sometimes it will also shut off by itself.
    When it powers up , all by itself , the led on the power switch is lit - and the current goes to 1600mAmp.
    When it shuts down the current will drop to 15 ~ 25 mAmp.
    On other times I can power it up , with the power switch.Sometimes it may take several tries.And then the current is ~ 1400 ~ 1600 mAmp.
    So , my question is , is there something not good with the new bios bins that I used to flash the main and EC bios chip ?
    I will post the original main and EC bin that I have saved from the bios chips.
    Can some of you , check them and say if ther is something wrong with them ?
    And can you say , why I have these different situations ?? Or do you have any suggestions what to try ?
    Thank you
    • 21485
    Re: Another 4730s HP laptop and some questions
    Post your bios in the "Bios Requests ONLY!" section please - https://www.badcaps.net/forum/forumdisplay.php?f=40
    • pecrie
      • Nov 2011
      • 182
      @SMDFlea sorry for that.I forgot that it is about the bios section
      • studdy05
        Bricked HP Probook 450 G7 Bios questions
        by studdy05
        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
        Ive got...
        07-08-2025, 09:24 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
