Acer A515 Not Charging
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Acer A515 motherboard, part number DA0ZAWMB8G. Someone tripped over the charging cord and broke the DC jack. Jack has been repaired, but system still doesn't detect charger.
    19V is present on charger pin and drain of #1 mosfet but there is no voltage on the gate and source. There is 19v on a small cap near gate. If battery is plugged in, #2 mosfet measures 10V on drain, nothing on gate.
    Mosfets are AON6414A. Datasheet https://datasheetspdf.com/pdf-file/7...ors/AON6414A/1
    Measuring in diode mode I don't find any short to ground on any of the surrounding caps.
    See attached image.
  • mielta
    • Apr 2015
    • 368
    Re: Acer A515 Not Charging
    Hi
    measure on the shutresistor (its the one with R01) if there is short to ground
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      diagram and sample measurements will help. In order to trigger the N-mosfet at the entrance, it must be 25v at the gate. Check the voltages of the charging chip.
      I'm not happy to be so strong. because it's not humanly
      • mgrharry
        • Sep 2016
        • 211
        • usa
        No short to ground on R01
        • mgrharry
          • Sep 2016
          • 211
          • usa
          Thanks for the schematic. Unfortunately me and schematics = I tracked down the boardview as well but compared to the Mac board views it's so minimal and disorganized it wasn't much help.
          What charging chip are you referring to Sametbey?
          • mgrharry
            • Sep 2016
            • 211
            • usa
            Here are some full size photos showing the entire board top and bottom.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Charging IC is a small black square chip and will have "BQ735" written on it like this: https://www.leakymosfet.com/products...735-735-qfn-20
              Find the IC on the board and measure voltage on the following pins and report back:
              1. Pin 20 (Vcc)
              2. Pin 6 (ACDET)
              3. Pin 5 (ACOK)
              • kiwin
                • May 2021
                • 11
                • Russia
                You have a broken power connector. It has 3 contacts. ++19 volts /GND and AD_ID. The AD_ID pin is not triggered in the connector. It should short to GND.
                  • 21896
                  Your motherboard is a quanta ZAW , i posted the schematic and boardview -
                  https://www.badcaps.net/forum/showthread.php?t=96065
                  • mgrharry
                    • Sep 2016
                    • 211
                    • usa
                    That makes a lot of sense since this happened right after cord was tripped over. I reflowed the 19v pin but maybe the ID pin is busted internally.
                    • mgrharry
                      • Sep 2016
                      • 211
                      • usa
                      No chip labeled BQ735, but I did locate BQ24780S
                      https://cdn.badcaps-static.com/pdfs/...272e9b220d.pdf
                      According to that, VCC is pin 28, ACDET pin 6, and ACOK pin 5.
                      VCC = 19.16V
                      ACDET = 0V
                      ACOK = 0V
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        VCC = 19.16V
                        ACDET = 0V
                        ACOK = 0V
                        I was referring to the initial attached schematic. Per new schematic provided by SMDFlea, charger IC is indeed BQ24780s.
                        ACDET should be 2.6V. Check if you have continuity (Ideally from ID pin in charger port) between pin3 (ADP_ID) of adapter input (PJ2) and pin2 of PQ17 . Also measure voltage on pin2 of PQ17 and report back.
                        Since you mentioned tripping over the cable, pretty sure the ADP_ID pin is the issue here.
                        • kjchatman
                          • Dec 2012
                          • 213
                          • united states
                          I have this board and it's dead. i'm wondering if this large chip near the charging port that circled red in the pic is a fuse. it has no continuity and is shorted to ground on one side
                          • mon2
                            • Dec 2019
                            • 14666
                            No. That is a bulk ceramic capacitor. One side is expected to be to ground.
                            Often, fuses that are surface mounted (like this part) are white in color for the body of the component.
                            For your repair attempt, start with where the logic board is powered. Then check that the power supply is making it from the external power adapter -> to the power connector -> to the mosfets that will enable / disable to charge up the local battery, etc.
                            Start with the meter in DC volts mode with black lead to ground. Red lead onto the DC power in jack. Guessing that for this laptop, the DCIN voltage is around 19 Volts and is a round barrel (coax) jack with center pin positive.
                            The more recent designs are with USB Type C power adapters.
                            • kjchatman
                              • Dec 2012
                              • 213
                              • united states
                              i'm getting 19v on pin 1 of bq24780s. shouldn't i get the same on pin 2?
                              • kjchatman
                                • Dec 2012
                                • 213
                                • united states
                                19v is actually on the vcc pin of bq24780s.
                                • Sephir0th
                                  • Oct 2020
                                  • 1289
                                  Share the actual issue of your Board, History If available and which measurements you did so far before proceeding with anything.
                                  FairRepair on YouTube
                                  • kjchatman
                                    • Dec 2012
                                    • 213
                                    • united states
                                    it wasn't detecting the charger. I removed pq9 to solve the issue
                                      Acer Aspire A515-56G-538J Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-56G-538J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56G-538J boardview and A515-56G-538J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-07-2024, 01:30 AM
                                      Acer Aspire A515-56-75EU Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-56-75EU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56-75EU boardview and A515-56-75EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 10:20 PM
                                      Acer Aspire A515-56-78YR Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-56-78YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56-78YR boardview and A515-56-78YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      Acer Aspire A515-56-509F Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-56-509F Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56-509F boardview and A515-56-509F schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      Acer Aspire A515-56-51UF Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A515-56-51UF Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56-51UF boardview and A515-56-51UF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 09:30 PM
