Notebok ASUS X510UNR no power on
  • Sergio Kub
    • Jul 2018
    • 172
    • Brasil
    Notebok ASUS X510UNR without power
    Tested and ok
    Keyboard - PWR_SW # ok and came to EC
    New BIN bios registered (I get 8,198 KB here)
    3.3 V and 5 V suspended Ok
    I don't have the layout, just the preview of the frame
    Please, any tips
  • Sergio Kub
    • Jul 2018
    • 172
    • Brasil
    Re: Notebok ASUS X510UNR no power on
    anyone can help me please
    • mon2
      • 14599
      Power down & remove the battery.
      Meter in resistance mode (ohms) -> check the resistance to ground on all grey coils on the logic board.
      You are looking for very low resistance coils which may indicate an issue with that power rail. Anything < 10 ohms is a suspect, for now.
      Battery is good on this notebook?
      External power supply is good? What is the voltage ?
      Can you confirm this external power supply is mating correctly with the DC power jack ?
      Trace it back on the logic board and see how far this power rail travels. Somewhere in that area, the power supply is failing to be passed through.
      Any liquid damage ? any blown / damaged parts?
      • Sergio Kub
        • Jul 2018
        • 172
        • Brasil
        Only 3 coils are with resistance below 10 Ohms, but they are close to the processor and I think it is normal.
        Battery ok, 11.30 V
        External power supply OK
        3.3V and 5V are present
        Memory Ok
        No sign of oxidation or liquid on the board
        • Sergio Kub
          • Jul 2018
          • 172
          • Brasil
          Ec ite it8995e-128
          1748-dxa
          • mon2
            • 14599
            Ok. Leave the coils alone - agree with the CPU core rails being low in general.
            From the boardview file, trying to trace the path of the voltage rail from this external adapter.
            Since you have 3v3 and 5v0 present - this portion of the design should be ok.
            You can measure the coils (voltage mode) on the logic board to determine which ones are not switching with the adapter connected.
            • mon2
              • 14599
              Have you seen this video ?
              https://www.youtube.com/watch?v=AthddvVG1Dk
              • Sergio Kub
                • Jul 2018
                • 172
                • Brasil
                Thanks, I haven't seen the video yet.
                I do not have the SVOD V3 yet, but I will purchase and try this procedure.
                It looks like it is a software defect, the basic voltages and power on are ok.
                Thank you very much and I will publish the result of the EC Flash
                • Sergio Kub
                  • Jul 2018
                  • 172
                  • Brasil
                  I will make these measurements with an oscilloscope and post the result
                  • Sergio Kub
                    • Jul 2018
                    • 172
                    • Brasil
                    In addition to the 3v3 and 5v0 voltages present, it also has that of P_1.0VSUS_PHASE_30.
                    All other coils have no voltage or pulse, pressing the power or connecting the external source.
                    It seems that there is no response from the EC to the low pulse (PWR_SW #) that goes to him, on pin 110.
                    • elton_002@
                      • Jul 2021
                      • BRASIL
                      Friend I'm having the same problem, I still don't have anything concrete, I've re-recorded the bios and nothing, I'm sending the boardviewr maybe it will help you.
                      boardview https://www.badcaps.net/forum/showthread.php?t=70050
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • ShadowAi
                        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                        by ShadowAi
                        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                        03-15-2024, 10:46 AM
                      • meraklinetx
                        Asus Z97-a power cycle, no boot no cpu voltage
                        by meraklinetx
                        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                        05-10-2023, 06:08 AM
