MacBook Pro Retina 820-00138 Black Screen
  • ACS-Repair
    • Feb 2021
    • 204
    I have an unusual problem with a 2015 MacBook Pro 820-00138 and I'm curious to see if anyone else has seen this problem. It has the integrated Intel Iris Pro graphics.
    When I turn it on, the screen is black with no backlight. If I connect an external Thunderbolt Display, I will see the extended display on that screen. If I tell the computer to mirror the displays, the Thunderbolt Display will also go black. If I disconnect the internal screen and connect only the Thunderbolt Display, I will have the main screen displayed there. I have tested the screen on another computer and it is known to be good.
    Is it possible for a part of the GPU to fail so that the primary display buffer would remain black?
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro Retina 820-00138 Black Screen
    If you tested the LCD on another computer and know for sure it works and turns on, I would test voltage on the LVDS connection and see if you are getting voltage there. Also test your Backlight fuse as well. if the backlight fuse is blown there is most likely a short on the board. Again your GPU is most likely fine on this model, these models usually dont have faulty GPUS in this year.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • ACS-Repair
      • Feb 2021
      • 204
      Hi Steven, thanks for your input, it's much appreciated. I believe I have the answer to this after doing a bit of research. Unfortunately I didn't mention that the known working screen was tested on a 2014 A1398, and that was the reason it didn't work on the 2015. I had bought a 2014 A1398 complete and I thought that the 2014 and 2015 screens were interchangeable, but my research tells me that is not the case. So it looks like even though the screen was recognized on the 2015, it wasn't going to work. It also explains why the screen buffer was black. It's another learning experience! Now I'm looking for a good deal on a 2015 screen.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Of course! Mid 2015 LCD models are only for MID 2015 models.
        A1398 LCD models go like this:
        Mid 2012/ Early 2013 - Use the same LCD in this year
        Late 2013/ Mid 2014 - Use the same lcd in this year
        Mid 2015 - Only one type of LCD in this year.
        Although the LCDs are identical in shape and size they are not the same. There are 3 types of Retina LCD models. This goes for 13" models as well.
        Also 15" Models in Touchbar go as follows:
        A1707
        2016/2017 Use the same lcd
        A1990 Uses a different LCD, and has true tone for the T2 Chip
        which is a 2018/2019 LCD
        These LCDs can look the same but have different part numbers on them. If you use an LCD that is not on a 2018 and from a 2017, the LCD will turn on but it will disable your webcam, true tone and keyboard backlight. And once you do that, you have to wipe your SSD drive and reinstall all your data with the proper LCD because it will wipe the serial off of the T2 LCD.
        sigpic
        • ACS-Repair
          • Feb 2021
          • 204
          Thanks for that explanation Stephen.
          I have just received a used/broken screen that is supposed to be for a 2015 A1398. I'm not convinced that it is working properly or may not be a 2015. There is a crack on the right side that affect only 3/4 inch of the right side. Most of the screen appears to be OK.
          What I find is that when the screen comes up, the backlight comes on and the screen becomes active, but the display remains black. I have it connected to an external Thunderbolt Display to monitor everything.
          It takes 13 seconds for the internal display to become active. This is all while the boot screen is active on the Thunderbolt Display but still on the Apple logo and progress bar. Graphics are a bit jerky, definitely not the same as when there is no internal display connected. The delay is trying to tell me something... on other MacBooks the Thunderbolt Display won't come up until after I login. If the screens are mirrored, The Thunderbolt Display will become active at the login screen.
          As a reference, this is the first time that an internal display has been connected to this computer. I'm at a loss to determine if this is a screen issue or a computer issue. I would appreciate it if anyone who has had a similar experience would comment.
          • ACS-Repair
            • Feb 2021
            • 204
            For clarification, when I say the screen comes up, I mean the backlight comes up. Brightness control works as it should. The pixels on the LCD appear to be working.
            • ACS-Repair
              • Feb 2021
              • 204
              Based on piernov's recommendation from another thread I have measured the voltages on pin 5 (3.3v), pin 9 (3.3v), and pin 28 (5.1v). These voltages are present at startup and last through for at least 1 minute. There is never picture on the screen and no backlight in stand-alone config (i.e. no external display). I have confirmed that this is a 2015 screen.
              I'm trying to determine if this is a logic board issue or something to do with the screen. I don't have another screen unfortunately.
              • ACS-Repair
                • Feb 2021
                • 204
                I tried another screen that I bought on ebay (broken) with much the same results. I get 1.65v at the chime on the LCD_HPD line even though there is no display or backlight until the login prompt. I thought that maybe this was related to the lid sensor but I put a magnet over it and got the expected response. I'm certainly not going to invest anymore into this until I can better understand the LCD startup sequence and determine what is missing or why the delay.
                • ACS-Repair
                  • Feb 2021
                  • 204
                  Just to close this off... it's been a while and I resolved this after finding a broken dual inductor on one of the data lines to the screen. It seems if any of these lines are broken the screen will not display anything, which makes sense. Thank you to all that participated.
                  • Simplebeans
                    • Sep 2021
                    • 135
                    Well done ACS-Repair!
                    • HTR-Informatique
                      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                      by HTR-Informatique
                      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                      I also changed the screen because the PC fell and the screen was broken.
                      I changed the battery with a new and original battery.
                      I also had corrosion/oxidation on the...
                      02-09-2025, 06:51 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • VcemPzd
                      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                      by VcemPzd
                      Hello everyone !
                      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                      04-28-2025, 10:14 AM
                    • DaniK
                      Acer Aspire E5-574-52RH - black screen
                      by DaniK
                      I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                      Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                      Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                      Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                      The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                      Symptoms are:
                      - random black screen after displaying Acer logo...
                      02-21-2024, 06:27 AM
