Toshiba Satellite - Locks up when plugged in
  • predator0357
    • Jul 2014
    • 159
    • Israel
    #881
    Re: Toshiba Satellite - Locks up when plugged in
    Originally posted by rievax_60
    I didnt even know that iron existed. It would take some practice to get the heat right. I use a K tip or large chisel tip. The rest depends on your soldering skill.
    Check the resistance of the CPU between the (+) and (-) pads before you start. Then check it after you have fitted the new capacitors to be certain there is no short circuit caused by the soldering.
    Hehheheheh but this iron is good.
    I will post some pics B4 and after with the multimeter😃
    Tnx 4 the help👍👌😃
    • tempro
      • Dec 2015
      • 15
      • bulgaria
      #882
      Will it not help if I try and put the motherboard in the oven ?
      • tempro
        • Dec 2015
        • 15
        • bulgaria
        #883
        For Toshiba l300 question
        • tempro
          • Dec 2015
          • 15
          • bulgaria
          #884
          Toshiba l300 motherboard: starts loading Windows, and immediately disconnect the laptop after 2 seconds starts again and so ad infinitum.
          Whether the problem is a capacitor?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            #885
            Yes this problem is usually caused by the Tokin capacitor.
            A working TV? How boring!
            • tempro
              • Dec 2015
              • 15
              • bulgaria
              #886
              When i bend the motherboard of the laptop it sometimes stops working ,or starts, or the video dissappers. Do you think i can try putting the motherboard in the oven for some time?
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                #887
                Hello guys!! Just opened a L300 with the same problems. Not working with power adapter. I immediately bought a new NEC/TOKIN but to my surprise when I tore up the laptop under the cpu was sitting a big like NEC/TOKIN capacitor named WR2R5122. Is that the same?
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #888
                  It is 1200uf. You need to replace it with 4x 330uf low ESR capacitors like 2R5TPE330M9.
                  Read more of this thread.
                  • tempro
                    • Dec 2015
                    • 15
                    • bulgaria
                    #889
                    Will try to TANT D4 SMD 680uF 4V- 4TPE680MI x2. WR2R5122-This has nothing to do soldered.
                    • tempro
                      • Dec 2015
                      • 15
                      • bulgaria
                      #890
                      On 4v ESR-18. A good must be ordered once-4x 330uf low ESR capacitors like 2R5TPE330M9
                      • Dimitrios
                        • Nov 2013
                        • 127
                        • Greece
                        #891
                        So can it be replaced with my brand new NEC/Tokin capacitor that I have already available?
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #892
                          You can try. It is lower in capacitance than the original so the computer might still be unstable. The NEC/Tokin capacitors deteriorate quickly and are difficult to solder without damaging it. Read more of this thread. There is a lot detail including the things to not do.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #893
                            I don't see why would anyone use Nec Tokin that is known to fail prematurely.
                            • Dimitrios
                              • Nov 2013
                              • 127
                              • Greece
                              #894
                              Tried to remove with preheater and hot air but the old cap literally went into pieces. Will try more bottom heat like reballing. It is a very tricky removal just like you said guys...
                              • atsio
                                • Oct 2013
                                • 819
                                • Greece
                                #895
                                None of the Tokins I replaced came back with a problem. It is very easy to remove and solder if you now how to do it. You are replacing a capacitor that was in service for at least seven years and probably had to cope with very high temperatures.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #896
                                  The preferred way to remove it is by prying it off the PCB. It is a long thread. You need to read as much as you can before it is too late for the mainboard. Post #863 also links to some detailed photos.
                                  • Dimitrios
                                    • Nov 2013
                                    • 127
                                    • Greece
                                    #897
                                    Thanks! Yes I took it apart easily after removing the top plastic. I put back my new NEC/TOKIN but I am reading ground on its pads. That is not normal I think Should I remove it and place it again??
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #898
                                      It can look like a short circuit with the CPU fitted. Remove the CPU and check again.
                                      • Dimitrios
                                        • Nov 2013
                                        • 127
                                        • Greece
                                        #899
                                        Hmm it was removed. Then I fitted same result...
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #900
                                          You could send us a photo although the problem would be tricky to spot. I have had no experience in soldering back an NEC/Token capacitor.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
