Toshiba Satellite - Locks up when plugged in
+ More Options
Posts
  • LucHV
    • Apr 2012
    Re: Toshiba Satellite - Locks up when plugged in
    G'day Speedandy,
    I have an A200 with same problem and need the caps. Do you still have them? If so, PM with details and I'll come around.
    • openupshop
      • Apr 2012
      • 12
      Hello -
      EXPERTS PLEASE PLEASE HELP----I am new to the boards. I've dealt and fixed many heatsink issues- and overall done countless pc repairs... However, first time I am stumped with my Sister's Toshiba Satellite L675D-S049. Identical issue, laptop runs perfect on battery, but once its plugged in, it freezes fairly quickly. I've noticed, the longer it has Not been used, the longer it takes to freeze when plugged in. Only hard reset works after freeze.
      I have looked everywhere and have tried countless suggestions, changed battery, power supply, turned off a processor, etc. etc. but same freezing issue arises.
      I finally saw the "Capacitor" fix on this site, however, it is posted for another model. Could someone please tell me if this would apply to the Toshiba L675D-S7049 as well?? And if so, which capacitors should I change?? possible location of them??? Suggestions on the replacement Capacitors I should use & how many???
      ....Any experts if you have a few moments to advise, please help...... I would greatly appreciate the help!
      • somisa8v
        • Jan 2012
        #203
        Hi to all grate people sharing knowledge in this form ,
        I faced same symptoms many times ,recently 4 months ago , solved with
        same method .
        Remember 1 case 4X330 caps used but the other one 6x150.
        Pictures and details soon ( when decent internet connection available )
        to : xpert71
        How exactly you did a reflow to the Token / NEC ???
        Isn't there a plastic cover that will melt, also isn't the heat will damaged the cap itself?
        • openupshop
          • Apr 2012
          • 12
          EXPERTS - Please look at attached.
          I have the same issue, Toshiba L675D-S7049 laptop works perfectly fine on battery. However, once plugged in, either immediately or after a bit of time, laptop completely freezes and only hard power shutdown does anything.
          I have tried countless remedies to no avail. I opened up laptop & attachments R pics of mobo. It does not have da NEC/TOKIN caps, however, there are:
          Mobo: NALAE LA-6053P
          Rev: 1A
          3 0E5 220 6.3V
          3 0G4 390 2.5V
          3 0J4 VLPS 330 2.5V
          (the little round metallic partially purple items in the picture attachments)
          If I am focusing on da wrong items, please let me know. Otherwise, which ones should I change and with what??? Please help, your assistance would be greatly appreciated!!
          If needed, I can take additional photos of different areas & post.
          PLEASE HELP....
          • heavymachines
            • Mar 2011
            • 1028
            Thanks again guys helped me solve yet another prob!!!!!!!!!!!!!!!
            • ryogadan
              • Apr 2012
              • 6
              • Italia
              #206
              Hello to all.
              I followed the instructions of the post with excellent results (no more artefacts), but the notebook still shut down occasionally.
              In the pictures you can find my solution
              Foto 1 - Removing Tokin with Dark IR
              Foto 2 - Removed
              Foto 3 - Cleaning
              Foto 4 - My solution
              Best regard,
              Daniele
              • somisa8v
                • Jan 2012
                #207
                areas & post.
                PLEASE HELP....
                hi , yep u r in the wrong area , the TOKEN/NEC is located in
                the other side of the mobo , directly UNDER the processor ,
                check that area and upload some photos .
                your laptop is AMD , that have more known issue
                regarding heat desipation , you may need to address.
                • narcoticx2
                  • Apr 2012
                  Originally posted by speedandy
                  No change. Spent a couple of hours googling and found this site. I've just ordered 10 TOKIN OE128 from Singapore. If anyone around Brisbane AU needs one PM me in a couple of days and I'll pass one on.
                  Hoping I'm not too late? Will send PM when i can (new member restriction :\)
                  • manuel76
                    • Sep 2011
                    #209
                    Hi sir benmah,
                    I replaced the NEC tokin 0E128 with 4 tantalum caps and it works pretty well.
                    Thank you very much.
                    • openupshop
                      • Apr 2012
                      • 12
                      Hello Somisa8v
                      Thank you so much for your reply. Unfortunately, there is no TOKEN/NEC in this motherboard. I have tried countless suggestions from the web and was very happy when I came across this forum because the issue on this thread was EXACTLY what I was experiencing, laptop works perfect on battery, but freezes either immediately or a little while after plugging it in. Consequently, I believe a similar solution exists for me since so many others on this thread have succeeded with replacing the capacitor(s).
                      I did take additional photos per your suggestion which are attached.
                      The first two pictures are each sides of the processor. I checked directly underneath the processor and throughout but no TOKEN/NEC.
                      If you could guide me, I would greatly appreciate it. If you need any additional information, please let me know.
                      • civismo
                        • May 2012
                        • Portugal
                        #211
                        Hello!
                        I have the same problem in this toshiba A500, but don´t see any NEC/Tokin capacitors like those here.
                        This motherboard of toshiba A500 works perfectly on battery, but it freezes few secons after DC is plugged
                        I tried already with another ram, cpu, power supply, external monitor only, even changed radeon vga card, and always shows this same behaviour.
                        Any suggestions ?
                        • civismo
                          • May 2012
                          • Portugal
                          #212
                          Well, at least now i know that it isn´t the faulty capacitor under the cpu
                          Still freezing windows normal mode, while in dc
                          • fardhan_rajab56
                            Paklar
                            • May 2012
                            • 49
                            • INDONESIA
                            #213
                            hi
                            i have a toshiba laptop L300
                            problem if the adapter is plugged directly leptop restart
                            please help me
                            only this time I can be a problem like this
                            Technicians fardhan leptop
                            • civismo
                              • May 2012
                              • Portugal
                              #214
                              Is this topic dead ? :P
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                #215
                                It's not only the capacitance that matters. Putting a great big 'lytic in there won't help if the ESR of it is too high to filter properly.
                                • fabiog
                                  • Jul 2011
                                  • 102
                                  #216
                                  Would cheap caps from hong kong do the job and how long would they last since they are oem.
                                  eg:
                                  http://www.ebay.co.uk/sch/i.html?_nk....c0.m270.l1313
                                  • guest7.3
                                    • Jan 2012
                                    #217
                                    eg:
                                    Those caps do work. As for how long they will work, I have no idea. I have them installed in my laptop but I have only had it back for two days.
                                    • blacklayan
                                      • May 2012
                                      • uk
                                      #218
                                      There is a guide here to how to replace the capacitor
                                      i hope it will be usefull...
                                      http://laptoprepairblog.net/toshiba-...er-plugged-in/
                                      • russell1981
                                        • Jan 2012
                                        • 32
                                        • bangladesh
                                        #219
                                        @all do not remove the NEC/TOKIN capacitor...if u have done this then
                                        this problem will come back.what u need to do see my pics.using 1*100uf capacitor(black one) & 5*10uf capacitor.do it.
                                        • russell1981
                                          • Jan 2012
                                          • 32
                                          • bangladesh
                                          #220
                                          Re: Toshiba Satellite - L300
                                          this problem will come back.what u need to do see my pics.using 1*100uf(or 220uf) capacitor(black one) & 5*10uf capacitor.do it
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
