Acer e5-576g no cpu voltage
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day.
    I've got an Acer E5-576G with no cpu voltage present when unit is turned on. Blue led light indicator is turned on and cpu fan spins. This happens when memory module is present in slot.
    Scenario A
    -When I turn on laptop WITH memory module inserted, cpu vcore shows 0v on PL3, PL4 and PL5 (page36) And voltage is present on vgpu core on PL7 and PL8 (page38) At this state, laptop turns on with no display.
    Scenario B
    -When I turn on laptop WITHOUT memory module. cpu vcore is now present on PL3, PL4 and PL5. But vgpu core on PL7 and PL8 goes to 0v.
    So there maybe something connected to both of this that is faulty. But it only happens when laptop is on S0 state.
    Wondering what should I do next. Thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer e5-576g no cpu voltage
    What is the Ram coil voltage-with ram inserted,without ram?? Vcore will come only if proper ram supply is there. Since with ram, no vcore-i doubt ram voltage is not proper. I assume you have tried a known good ram module. Bios Flashed??
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Good day my friend. Ram voltage is 1.35v with or without ram installed. And yes I tried different working ram.
      One thing I also noticed is that +1.35v gfx voltage on PL2 is also 0v when ram is not installed. (page39) I has 1.35v when ram is installed.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        GFX voltage is not supposed to be there without Ram.
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          I see. well most likely there's a short either with the gfx or ram supply area that has conflict between cpu vcore. I don't know if injecting voltage will help since short happens after powering up. Finding the component that's heating up may be difficult because as of now, my best bet is using thermal camera which i do not have. Maybe i will try to remove gfx coil and ram coils too.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I think this mb can be converted to UMA by removing graphics power coil. Can u mention the mb marking to be sure?? That way you can rule out graphics issue. No pint removing coils un-necesaarily unless we find the fault. I still suspect something wrong in ram circuit based on symptoms as you have not provided any measurements.
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
              09-06-2024, 05:27 AM
              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-07-2024, 05:00 AM
              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
              Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
              This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 04:10 AM
