HP Envy x360 15-w237cl Help!! Need to replace a blown component
  • eskimojo47
    • Mar 2021
    • 10
    Hi All,
    Was trying to clean the dust and while replacing the component in the attach pic burnt out and smoked.
    The laptop model is HP Envy x360 15-w237cl.
    End goal is to replace it with the same part or an equivalent. Would appreciate any help or advice towards that goal.
    I've tried to google for this laptop model number and the component ID U52202 (See pic), but nothing shows up.
    Pic of the burnt component:
    https://ibb.co/jWrWmxg
    The print says HC6MB (to the best of my ability to read)
    Pic of the MB Part number:
    https://ibb.co/bFmk4CR
    Pic of the replacement part number:
    https://ibb.co/M91wfFC
    Thank you for all/any help!
    Joe.
  • R_J
    • Jun 2012
    • 9588
    Re: Help!! Need to replace a blown component and can't identify the part!
    It might be a SY6288C6AAC
    • eskimojo47
      • Mar 2021
      • 10
      Thank you so much!
      I found a video that referred to that specific component (https://www.youtube.com/watch?v=QE4wuuVD06I), but the laptop model was different. Also, the technician in the video couldn't conclusively determine why that component blew out so frequently.
      Should I just try it out? and if it's the wrong component, could it cause further irreparable damage?
      • eskimojo47
        • Mar 2021
        • 10
        The motherboard is this:
        Laduree-Sky
        14263-2
        448.06202.0021
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3622
          • slovakia
          his component was HC6LA and your is HC6MB so it can be same part.
          as his laptop was Spectre x360 and your is Envy x360. i think it is the same component
            • 21606
            I agree with you and R_J ,seems right.
            https://www.ebay.co.uk/itm/164393467374
            HC7YA HC6 HC SOT23-5 .The part number is HC***
            • eskimojo47
              • Mar 2021
              • 10
              Thank you for your help! I will look up that number. There was a suggestion that it could be a slightly different part number, based on the following circuit diagram. Do you think it's the same as what you're mentioning? I'm not an electronics engineer, so am having a hard time tracking down this part.
              https://ibb.co/Dfysc82
                • 21606
                The motherboard makers can use different suppliers for pin to pin compatible parts.
                See the attached screenshot from a SY6288C6AAC (Wistron Husk Petra -4M Schematic) ,pin 4 is NC not connected, there is no copper trace between 4 and 5.There`s no datasheet for the silergy part. If the richtek part doesnt work with just pin 5 as Vin you could solder pins 4 and 5 together
                https://cdn.badcaps-static.com/pdfs/...59b8da413a.pdf
                • midesroc2012@gmail.com
                  • Nov 2021
                  Originally posted by eskimojo47
                  Hi All,
                  Joe.
                  Hi there, I too have a blown chip on my board, can I add picture here, if not, how do I make a new post? I'm new in the forum, thanks.
                  • mon2
                    • 14631
                    Yes. At the bottom of the text editor should be a box that reads "Attach files". Select it to proceed. See attached.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3622
                      • slovakia
                      before replacing component removeburned and check forshort. regulator dont burn itself
                        • Nov 2021
                        Sounds great, I will check for grounds first, good idea.
                        Here's a photo of the chip U3501, need to I.D. the exact part please.
                          • Nov 2021
                          Hi again, wondering how to, make a new post, since I am not getting any replies on my last entry.
                          Please send me a note to get my new post going, thanks, Michel.
                            HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                            This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 12:18 PM
                            HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                            09-06-2024, 11:17 AM
                            HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                            This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 06:51 AM
                            HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 06:50 AM
