MacBook a1466 820-3209-a No Power No Fan vol fluctuating loop
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Short Question is What can be wrong in the circuit that I have a current loop fluctuating from 9 to 5v, what i ve checked:
    I have a 820-3209-a (macbook a1466 from 2012) Connect charger from my power bench and green led appear and then orange. The F7040 in the picture attached shows 9.06Volt for 3 seconds then decreases slighttly to 5vol in a loop, then 9,06V again and so on. no fan. consumptions goes from 18mah and then 6mah in that loop...
    I have checked U7000 : AC OK, DC IN , AC IN, VDD, VDP are fine i think.....
    capacitors arround are not shorted....
    I have disconected one side of the L7030 coil to see if the problem is in the CHARGE side of the system or in the power supply side, and the problem is still with the coil disconnected from one side, so problem is in the power supply side, any hint willl be much apreciated..
    Marcelo J
  • mon2
    • 13994
    Re: MacBook a1466 820-3209-a No Power No Fan vol fluctuating loop
    Check your current sense resistors. If any of these parts are missing or open, the regulator will think too much current is being drawn and will shutdown to protect.
    • marce002
      • May 2018
      • 316
      • Argentine
      thanks mon2 , I will test it, I also wanted to say that the 3.3v and 5v power supply that uses a TPS51980 (UT201) has no output to the coils!! but it is enabled in both EN1 and EN2 and has REG2 and REG5 ok, also VIN is ok , and no PGOOD1 nor PGOOD2 (they are are 0v.)... can this mean the IC is faulty and make the IC in my previous post drop the current in a loop?
      PD how can disable this TPS51980 to check if the main 9vol remains stable?
      Marcelo J
      • mon2
        • 13994
        hi.
        1) this is U7201 (TPS51980)?
        2) Vin value on pin 23 ?
        3) Good if you see VREG5 (pin 29) and VREG3 (pin 22) operational. Post their values for clarity. These rails should always be on as noted in the schematic. These are LDO (low drop out) regulators and are linear so no switching mosfets nor coils needed. Respectively, they "burn" the input voltage down to the lower voltage so they are only for low current loads as to not cause too much heat rise from this voltage conversion.
        4) Post the voltage readings for EN1 (R7251) and EN2 (R7252).
        5) With power off and the battery removed, using your meter in resistance mode, what are the coil readings @ L7220? L7260?
        If these readings are low then there could be a shorted cap on the respective rail. Or could be a local bad mosfet that is not switching.
        These regulators are quite common in Asia and should be easy to source. Good to grab a few for testing.
        Yes, if this regulator is not operational then certainly other legs of the logic board will fail to operate correctly.
        • marce002
          • May 2018
          • 316
          • Argentine
          Mon2 thks!!!!!!!!!!!!!!!!!!!
          1) yes
          2) pin 23 ? it is: 9.1v and other relevant:
          12=3.4v
          4=4.95v
          21=3.41v
          5=0v
          20=0v
          23=9.1v
          22=3.3v
          29=5v
          posted above
          pin 4 and 21 above
          ok they are:
          L7220=2.61kohm
          L7260=2.22kohm
          and
          L7030=0.574kohm
          Marcelo J
          • marce002
            • May 2018
            • 316
            • Argentine
            Mon2 Remember that with the coil open or lets say the fuse f7040 removed i still have that unstable loop volt from 9v to 5v in PPBUS_G3H...
            problem before any 5v or 33v generation at TPS51980...
            so should look 4 issues "before the FUSE" ,,, what to look at?
            thanks very much
            Marcelo J
            • mon2
              • 13994
              Hi. I think we are working on exactly the same logic board at the office today. Bought from eBay and the seller said no idea on what is wrong. The logic board is missing many parts... thieves. We will rebuild it.
              Check your current sense resistors on the bottom right of the same regulator. Confirm their values and they must reach the regulator.
              If this area is broken then regulator will believe too much current is being drawn and will enter shutdown or hiccup mode like you are observing.
              • mon2
                • 13994
                Check r7050, r7051, r7052.
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  Mon2
                  from the side of charger the sense resistors are ok they are 10ohm each one: r7021 and r7022. and R7020 is 0,5ohm
                  In the battery side although I have:
                  r7050=0.06ohm
                  r7051= 10.4ohm *a bit off
                  r7052=0.8ohm
                  here is a picture of the wrong resistor, coud it be the culprit? can i make a bridge with pliers to do a fast check removing the existing one? pliers are 1,5ohm
                  Thanks a lot
                  Marcelo J
                  • marce002
                    • May 2018
                    • 316
                    • Argentine
                    I ve replaced that ugly resistor with a 2.8ohm and verified its path to the chip on each leg and is ok. but same thing, the fan does not spin.... so sad... maybe the chip is bad but i dont think so because has most of volt values ok (its cheap anyway).... what else to look at..
                    does not work also on battery only... nor power supply at 14.6v Magsafe 2 cable... only green led and amber after 3 seconds.
                    BATTERY ONLY
                    I have 7.55V steady on fuse f7040 .. not any other coil with vol. not spining. charger disconnected.
                    BATTERY AND CHARGER connected
                    I have 9.08 V o and 17mah steady on fuse
                    Marcelo J
                    • mon2
                      • 13994
                      1) what is the voltage @ J6901 - pins 1 & 2?
                      2) voltage @ D6905, pin 3?
                      3) voltage @ L6995, pin 2?
                      4) Q7080, pin 1 ?
                      5) D7005, pin 3?
                      6) remove the battery and confirm if the voltage (PPBUS_G3H) still is oscillating.
                      7) If you remove L7030 - the switching regulator will no longer switch. Instead, remove F7040. Then measure the voltage @ L7030 pin 2. Do you see a higher and steady voltage on this rail? Value?
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        J6900??? :1= cant measure because is the cable attached to the connector right?goes to a 8 pin component called q7080 =VFRAN .most of the 8 pines are steady 14,5V or power supply volt. one is 0V and the other pin is 13.93-13.81 loop.
                        2) voltage @ D6905, pin 3? varies little from 14.05v to 14.06v
                        3) voltage @ L6995, pin 2? 3.41v
                        4) Q7080, pin 1 ? (see point 1 above)
                        5) D7005, pin 3? 14,13v
                        I ALWAYS HAVE THE BATTERY REMOVED in the tests, with only battery is steady, i do not know if the battery is good by remains stable at 7.55v
                        FUSE REMOVED not STEADY, loop from 9.06 to 2.3v note 6seconds is 9.06 and 6 seconds down to 2.3v ...all this in a infinite loop like I said in the 1st post of this thread.
                        Bad luck still can I inject some volt to test somewhere? is your board the exactly the same? as i do not have J6901 DO YOU HAVE U7090? i do not see any 5v (5.5v "G3Hot" Supply) generation and i do not have any u7090 at all!!
                        Marcelo J
                        • marce002
                          • May 2018
                          • 316
                          • Argentine
                          update: same situacion but now have stable and steady 8.4V PPBUS_G3H no more loops and 17mah total consumption...
                          still no spin , I do have green led , then amber on my magsafe2 cable attached to my power supply. (what I think I did to solve that is resoldered the u7000)...
                          but still (UT201) has no output to the coils ...
                          Marcelo J
                          • marce002
                            • May 2018
                            • 316
                            • Argentine
                            Hello
                            LAST UPDATE!!
                            In order to do something with this mother , since it belongs to me, no worries
                            I have injected 3.3v and 5V with external sources to the corresponding places and I have made 'powergood' them. Now I have fan spining and all coils have its values ok (except for L9701 and L7550 but think is normal compared with another exact board) BUT no video NO chime .... I have USB activity and BIOS too.... when connecting display NO BACLIGHT/IMAGE at all... but when I attach a pendrive it acts like if it would be reading data.... led blinks normal...
                            QUESTION IS: THIS MEANS CPU IS OK? (vcore are fine on coil)... fuse F9700 backlight is ok, and ALL_SYS_PWRGD is good 3.3v too. 400 to 600 mah and fan accelerating
                            thanks for any idea!!!
                            Marcelo J
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              Las update
                              Just to keep this alive, and to anyone reading, I hear a chime! so not dead CPU/PCH, but no image ....I suspect of the U9701 because no 20v are generated at L9701 even if the enable signal PPBUS_SW_LCDBKLT_PWR is present...
                              Marcelo J
                              • mon2
                                • 13994
                                If you are still working on this case...
                                Yes, review page 65 of the schematic.
                                1) check F9700 for the backlight boost regulator Vin fuse.
                                2) PPBUS_SW_LCDBKLT_PWR voltage value ?
                                3) LCD_BKLT_EN voltage value ?
                                4) BKLT_PLT_RST_L voltage value ?
                                Changing the LP8550 is a common repair - available from Arrow or TI.com webstores.
                                • Cemal Odabasioglu
                                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                  by Cemal Odabasioglu
                                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                  Observations...
                                  01-14-2025, 03:54 PM
                                • psdavid65
                                  Macbook Air A1466 820-3437-B Booting Problem
                                  by psdavid65
                                  I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                  06-20-2024, 12:27 AM
                                • ronelex
                                  Macbook Air A1466 Fluctuating 3v supply
                                  by ronelex
                                  Hello
                                  I got this unit with orange light but wont boot up
                                  I notice that its L7560 3.3v supply is fluctuating
                                  this is the reading I got on its PWM U7501 TPS51890A
                                  pin 4- EN1 - 0v
                                  pin 12 - EN - 3.3v Fluctuate
                                  pin 21 - EN2 - 3.3v Fluctuate
                                  pin 22 - vreg3 - 3.3v ok
                                  pin 23 - vin - 8.62V
                                  pin 29 - vreg5- 5v fluctuate
                                  I already check the power rails line in page 62 but I didn't find any short on those lines. I already tried replacing the pwm but same issue.
                                  I hope you can guide me where I can look for the fault of this...
                                  02-07-2023, 04:39 AM
                                • No Lan
                                  [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                  by No Lan
                                  Hey everyone,
                                  Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                  Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                  Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                  05-24-2025, 03:09 PM
                                • echothegamer
                                  Macbook A1466 dies when charger disconnected
                                  by echothegamer
                                  Hello all,
                                  Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                  Details:
                                  Macbook 13' A1466
                                  Board (820-3209-A)
                                  Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                  Pictures below of Boardview and schematic...
                                  I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                  It's an older model and it is very likely that battery has become...
                                  10-28-2023, 12:00 PM
