Macbook Air A1466 Fluctuating 3v supply
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Hello
    I got this unit with orange light but wont boot up
    I notice that its L7560 3.3v supply is fluctuating
    this is the reading I got on its PWM U7501 TPS51890A
    pin 4- EN1 - 0v
    pin 12 - EN - 3.3v Fluctuate
    pin 21 - EN2 - 3.3v Fluctuate
    pin 22 - vreg3 - 3.3v ok
    pin 23 - vin - 8.62V
    pin 29 - vreg5- 5v fluctuate
    I already check the power rails line in page 62 but I didn't find any short on those lines. I already tried replacing the pwm but same issue.
    I hope you can guide me where I can look for the fault of this unit
  • mon2
    • 14544
    Re: Macbook Air A1466 Fluctuating 3v supply
    What is the ppbus_g3h voltage to ground? (Check at the fuse)
    Is the 3v42 rail stable?
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      ppbus_g3h- 8.62v
      3v42 is stable
      current stuck on 0.02A
      • mon2
        • 14544
        What is the 820-**** board number for your unit ?
        • mon2
          • 14544
          Remove all power. Meter in resistance mode.
          What is the resistance to ground of PP3V3_S5_REG_R ? (L7560)
          • ronelex
            • Oct 2016
            • 195
            • Philippines
            820-0165 sir
            What is the resistance to ground of PP3V3_S5_REG_R ? (L7560) - 400 ohms
            • mon2
              • 14544
              400 ohms
              That is too low of a resistance for this rail. This is likely causing the fault with the current sense loop observing a heavy load and power pulsing this rail.
              With flux and patience, lift up one leg of L7560.
              Then measure the resistance to ground again on the PCB pads of L7560.
              Which side has this 400 ohm resistance to ground ?
              Is it producer side (U7501) or the consumer side (L7560, pin # 2) ?
              Do you have an adjustable power supply that can support 1 volt (NOT HIGHER)?
              • ronelex
                • Oct 2016
                • 195
                • Philippines
                consumer side pin 2
                Yes i got a PSU Bench here and also thermal cam but it is in the shop im at home right now, only psu is available
                • mon2
                  • 14544
                  Do wait for other comments but there is someone who is partially shorted on this consumer side of the rail.
                  Suggestion is to inject 1 volt (not higher) but ok to use higher current. The idea is to heat up the defective part and use your thermal camera to locate that part.
                  You want to keep the voltage as low as the lowest power rail in case a high side mosfet is leaking (ie. that may power the CPU rail). The CPU cannot handle a high voltage.
                  Hoping that the short is a shorted capacitor (most likely - the tantalums are the worst for this but have seen ceramic non-polarized caps as well with the same fault).
                  • ronelex
                    • Oct 2016
                    • 195
                    • Philippines
                    ok sir thanks for your guide, I try to check all the power rails and I dont see any shorted circuit, I just try to intect this 3v line tomorror,
                    • mon2
                      • 14544
                      Tomorrow, also check the resistance to ground of vreg5 (pin 29) which you have reported is also fluctuating ?
                      • reformatt
                        • Feb 2020
                        • 1445
                        Take off the heatsink from the CPU and check the PCH portion of the die for damage. Also check resistance to ground of L7630. Seen these shattered and you can just be wasting your time.
                        • ronelex
                          • Oct 2016
                          • 195
                          • Philippines
                          i tried to hang up the L7630 and the fluctuate stop, I will check now the CPU now
                          • ronelex
                            • Oct 2016
                            • 195
                            • Philippines
                            I open the heatsink and the cpu is looks good no crack on the top of it
                            • reformatt
                              • Feb 2020
                              • 1445
                              You need to get to stable PP3V42_G3H, PPBUS_G3H (8.6V no battery), and PP3V3_S5. Then troubleshoot from there with PM_SLP_S4.
                              • ronelex
                                • Oct 2016
                                • 195
                                • Philippines
                                PM_SLP_S4 not generated,
                                i check the 11 signal
                                1. PPVRTC_G3H - 3.42v
                                2. RTC_RESET_L - 3.42v
                                3. PCH_SRTCRST_L - 3.42v
                                4. PCH_INTVRMEN - 3.3v
                                5. PCH_DSWVRMEN_L - 3.24v
                                6. SYSCLK_CLK32K_RTCX1
                                7. PP3V3_S5 - fluctuate
                                8. PM_DSW_PWRGD - 0
                                9. PP3V3_SUS - 0
                                10. PM_BATLOW_L - Fluctuate
                                11. PM_RSMRST_L - 0
                                +1. PM_PWRBTN_L - Fluctuate
                                I thinks my main issue is this PP3V3_S5
                                • reformatt
                                  • Feb 2020
                                  • 1445
                                  PP3V3_S5 resistance to ground on a working board should be over 3K. You said earlier this was 400 ohms so something is not right there which is why I said you look at the PCH first. The supply should still be stable even with that low resistance.
                                  Look for corrosion on U7501, especially near pins 9 through 16 as I often see liquid damage here.
                                  • Cemal Odabasioglu
                                    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                    by Cemal Odabasioglu
                                    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                    Observations...
                                    01-14-2025, 03:54 PM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                    03-31-2024, 02:12 PM
                                  • psdavid65
                                    Macbook Air A1466 820-3437-B Booting Problem
                                    by psdavid65
                                    I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                    06-20-2024, 12:27 AM
                                  • echothegamer
                                    Macbook A1466 dies when charger disconnected
                                    by echothegamer
                                    Hello all,
                                    Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                    Details:
                                    Macbook 13' A1466
                                    Board (820-3209-A)
                                    Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                    Pictures below of Boardview and schematic...
                                    I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                    It's an older model and it is very likely that battery has become...
                                    10-28-2023, 12:00 PM
