What makes a GPU reflow last longuer ?
  • Pedro90
    • Mar 2021
    • 7
    • Morocco
    Hi am new to this board and am practicing hot air station refliw on some laptop gpus .
    How i can improve reflow life time ?
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: What makes a GPU reflow last longuer ?
    you can disassemble and install SMD chip with a similar hot air station. but you should not interfere with the chips in the BGA foot structure, such as the GPU. good works
    I'm not happy to be so strong. because it's not humanly
    • Pedro90
      • Mar 2021
      • 7
      • Morocco
      Hi and thanks for your quick replay .
      So do you mean i should not heat the gpu die and only the sides?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3609
        • slovakia
        reflow is NOT repair. it will last as it can, but havy gaming and u have it back within week
        if u want to reflow u MUST have preheater. 70% of heating power must comes from preheater
        if u wanna practice, than practice with reball. dont waste your time on reflow
        • piernov
          • Jan 2016
          • 4437
          • France
          https://www.badcaps.net/forum/showpo...02&postcount=2
          2.1. Never reflow large BGA
          It won't fix the problem since 99% of the time it's not an contact issue between the BGA and the logic board. There's a high risk of damage the board even further.
          If you want to confirm if an AMD/NVidia chip is bad, you can heat it up to 200°C max for a minute and a half, no flux. It'll come back to life for a short while and then die again, because it's bad. In this case it has to be replaced.
          • Pedro90
            • Mar 2021
            • 7
            • Morocco
            Ok thanks mate . What would be an affordable beginner bga reball station or something i can build up.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Most "beginner" bga reball station, while cheaper, they usually have rather poor calibration and require some experience to gauge when the chip has reached reflow temperature. Otherwise it is very easy to damage the chip, or worst, damage the board itself due to the latter delaminating, etc.
              If you are new to soldering, i'ld suggest you start by practicing through hole soldering using a 'normal' iron with a proper tip and SMD soldering (you can get by with a cheap Chinese one, they are OK for small jobs).
              • Pedro90
                • Mar 2021
                • 7
                • Morocco
                Ok better send those bga chips for professional reball.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  You would only need to reball if you are replacing a bad chip with a working used chip. Reballing a bad chip has no point.
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    Unless if you want to practice reballing. Since the chip is already dead, you dont have to worry about killing it and/or ripping pads when pulling stencil out
                    • coltron
                      • Jan 2021
                      • 98
                      • England
                      How can you confirm a good reball if the chip is already shot?
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        • Romania
                        I still wonder about it - why do some reflows (with flux, that is.) last a lot of time, and some die within weeks?
                        Let me show you two cases - one that lasted about two weeks, the other still works for 2 years already:
                        1. Packard Bell MB65 - G86-703-A2 - reflowed countless times because every time it would die after 2 weeks.
                        2. HP Pavilion dv6723 - G86-730-A2 - reflowed just twice - first time it worked for 6 months, and died with a white screen, opened up, reflowed it again and it's been working since 2018, and in early to mid 2000s games (which did seem to take a toll, especially since all were maxed out on a 1680x1050 panel I installed from an ASUS G1 - the game it originally died on was Ford Racing 2.)
                        Maybe proper cooling is a key in having those last longer? The heatsinks on the MB65 were really gutless compared to the dv6700. Just my 2 cents, and of course I can be horribly wrong about this.
                        Main rig:
                        Gigabyte B75M-D3H
                        Core i5-3470 3.60GHz
                        16GB DDR3-1600
                        Samsung SH-224AB DVD-RW
                        Delux MG760 case
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          Both these GPU are affected by NVidia bumpgate. Heating them at 200°C will soften the underfill and the bumps between the die and the substrate, so that they make contact again, but repeated heat cycles will damage them again. On top of that the die has hot spots, it doesn't heat up uniformly creating even more stress. So yes, keeping them very cool will help as they will suffer much less stress from thermal expansion of the die.
                          The fixed revisions with "good" underfill and bump materials won't fail that way.
                            HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                            09-12-2024, 02:20 PM
                            MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                            This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                            09-07-2024, 05:20 AM
                            HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            09-06-2024, 06:00 PM
                            09-06-2024, 12:30 PM
                            HP EliteBook 830 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 830 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + UltraSlim Docking Station boardview and 830 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            09-06-2024, 10:56 AM
