Lenovo E560 NM-A561 - ACPI BIOS ERROR when install windows
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Hello.
    Have this Lenovo E560 NM-A561 that get BSOD - ACPI BIOS ERROR when start to install windows 10
    reflash bios and still the same
  • petehall347
    • Jan 2015
    • 4423
    Re: Lenovo E560 NM-A561 - ACPI BIOS ERROR when install windows
    When the system asks you to install storage drivers, please press F7 on the keyboard (the key may be different on other computers).
    The system will disable ACPI for you automatically. Then, you’re able to continue your installation.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3553
      • slovakia
      it print error just few seconds after installation start, so i cannot press anything
      • petehall347
        • Jan 2015
        • 4423
        Restart the computer to restart Setup.
        When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
        Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
        • petehall347
          • Jan 2015
          • 4423
          just for testing purposes . you could try installing linux . it should make it easier .
          • RJARRRPCGP
            • Jul 2004
            • 6301
            ACPI and AHCI are not related.
            ACPI is advanced configuration power interface, IIRC.
            That error isn't normal for 10, BTW!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3553
              • slovakia
              ubuntu live work normal,
              windows 7 says "BIOS in this system is not fully ACPI compliant"
              i try to flash main bios but nothing changed. i try to flash EC but my vertyanov dont want to comunicate with it
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Look for "OS Optimized Defaults" option in bios setup and change it to win7.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3553
                  • slovakia
                  have only enabled or disabled.
                  enabled/to meet win8 cert/ - windows 10 install - ACPI BIOS ERROR
                  - windows 7 install - restart after few seconds
                  disabled - win10 - ACPI BIOS ERROR
                  - win 7 - BIOS not compliant with ACPI
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    Linux kernel logs should say something about ACPI.
                      • 20311
                      What bios version is it running now and how did you update it,did you flash with a bios update ISO or flash it with your programmer.Version 1.33 has an ACPI fix .
                      https://download.lenovo.com/pccbbs/m.../r00uj27ww.txt
                      <1.33> (Fix) Fixed an issue where Operating System cannot recognize custom ACPI Table.
                      If its newer/latest than that try the lenovo recovery key
                      https://forums.lenovo.com/t5/ThinkPa...3841031?page=3
                      https://support.lenovo.com/us/en/sol...b-recovery-key
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3553
                        • slovakia
                        bios is 1.4
                        try recovery key but it do the same
                        DMESG in linux tells me that is some BIOS _OSI firmware bug.
                        Laptop have fall from 1m
                        reflowed pins of SIO to clear that is no crack, but nothing changed
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3553
                          • slovakia
                          any hint what can be wrong?
                          • rediii
                            h???, spurrrn
                            • Mar 2018
                            • 485
                            • somewhere in europe
                            try to install windows 10 externally via another device (if possible), reinsert ssd and try to install drivers etc. make me firmware update
                            • zzzbgd
                              • Aug 2021
                              • Serbia
                              Any updates on this problem?
                              I have a same problem with T460s, updated BIOS to 1.52 version, tried with inserting ssd with already installed win 10, nothing helped so far.
                              • 3DIL
                                3D!L
                                • Jun 2021
                                • 42
                                • BRASIL
                                ok no problem let's try it the old way, you have to create an installation dvd with the version you want of Windown and run from this
                                • piernov
                                  Compaq SR1000 MSI MS-6577 ACPI fix
                                  by piernov
                                  Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
                                  ACPI fix!
                                  Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
                                  Bug
                                  Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
                                  At boot, you may be greeted by the following message:
                                  Code:
                                    [ 0.000000] ACPI Error: A valid RSDP was
                                  11-30-2021, 02:34 PM
                                • giagiuf
                                  Lenovo W530 1802 Error when I install a new wifi card Intel AX210
                                  by giagiuf
                                  I will try to install an Intel AX210 chip in to my Lenovo W530 but i receive the 1802 Error, what can i unlocked BIOS and Whitelist removed?
                                  Please let me know as soon as possible.
                                  Best Regards,
                                  Giagiuf
                                  09-20-2024, 10:24 AM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
                                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                  09-06-2024, 06:40 AM
                                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                  09-06-2024, 06:06 AM
