Hi, I have repaired the DC charging jack on my daughter's Samsung Np3530EC laptop, the laptop doesn't turn on with the charger and no LED'S light up, if I put in a charged battery from my other identical laptop it will power up and turn on, so it only switches on with the battery not the power supply which I can confirm 100%works. I have tested the motherboard power and I have 19volts on the board at the DC jack, so I know the charger and DC port are okay.I have checked the schematic diagram for the laptop and immediately after the DC jack are two smd components which seem to link one track on the board to another, I get 19v on one side but virtually nothing on the other side, they are plain black rectangles with silver ends with no numbers on the top, I'm struggling to identify them, could they be jumpers, resistors or inverters? Where can I buy them and how can I find the correct values? They are on the picture to the left of the DC power jack situated side by side,Thanks, any help appreciated....cheers
Laptop not turning on with power supply
Re: Laptop not turning on with power supply
They seems to be Coil. Check continuity in diode mode of multimeter. Check resistance on both sides of these coils. -
Hi, thanks for the reply, I have tested continuity of the two coils and they have continuity in diode/continuity mode of my multimeter of around .002 ohms, should I see 19v in and out of these coils ? I will post a pic of the schematic diagram, thanksComment
Yes, there should be 19V on both sides of coil as continuity is there. However, if you are not getting 19V on the other side, then most likely you have short on 19V rail. That's why i asked for resistance on both sides of those coil.Comment
Probes not making good contactOpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
If by accident I found the problem, I checked the board again going over the continuity of the coils but I forgot to disconnect the power supply so when I probed the one coil it sparked as it made contact with the solder pad it's supposed to be soldered to, I've reflowed both coils adding a tiny bit of solder now it works!!
Thanks again for the helpComment
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 06:00 PM
- Loading...
