Acer laptop with LS-E892P motherboard - 10 mA
  • Askic
    • Sep 2018
    • 187
    • BIH
    I have a laptop Acer with motherboard LS-E892P. The first input MOSFET was OFF (PQ302) and the next PQ303 was also off and voltage was not present after it. So in order to troubleshoot, I baypassed this first MOSFET and after that 19V was present on the motherboard (through FW diode on second MOSFET). Motherboard doesn't start and the current is about 10 mA. There is no short circuit. On LB1 is present and stable +3VLP_EC (3.29V), this voltage is present on superIO chip. On SPI ROM chip (BIOS), on pin 8 +3VALW_SPI is not present, there is 0 V.
    Attached is the schematics for LA-E891P, but it is very similar. I wonder what to inspect next.
    Schematic -> https://www.badcaps.net/forum/showthread.php?t=123071
    Thank you.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Acer laptop with LS-E892P motherboard - 10 mA
    Voltage on PQ303 all pins & BQ24735 all pin & RT6575 all pin ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      +3VALW & +5VALW will be generated after power on. So you are not supposed to get any voltage at pin8 of bios chip. Go by @techtiger's suggestion and fix the input keys not opening first.
      • Askic
        • Sep 2018
        • 187
        • BIH
        @mcplslg123, thank you for the clarification. I thought that ALW means ALWays.
        I have measured voltages on all pins.
        PU301 (BQ24735):
        1->18.2V 2->18.2V 3->18.6V 4->18.4V 5->0V
        6->2.3V 7->0V 8->3.3V 9->3.3V 10->0.78V
        11->3.1V 12->3.1V 13->3.1V 14->0V 15 ->0V
        16->6V 17->5.8V 18->3.1V 19->3.1V 20->17.8V
        PU401 (RT6575):
        1,2->0V 3->3.2V 4,5,6,7->0V 9->4.5V 10->0V
        11->0V 12 ->17.8V 13->1.3V 14,15,16 ->0V
        17->1.1V 18.19->0V 20->3.3V
        On PQ303 all pins have 18V
        • Techtiger
          • Oct 2014
          • 1602
          • france
          PU301 (BQ24735):
          PU401 (RT6575):
          ACIN is not recognize by KBC, your ACDRV is low +18V since you have jump the first fet 2nd FW there is a drop voltage you have to solved (BQ24735) fist to move forwed on ACDRV line you have 2 components check if they are faulty
          for RT pin 13 must be LDO +5V in you case 1.3V EN 1 is 3.3V but EN2 0V pin 12 voltage is low
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            ALW-Yes it does mean Always but on newer platform there is concept of suspend logic and "Deep Sleep Well". Thats why you will notice consumtion of say eg 0.015ma at the beginning and after a while it will drop to say 0.004. Thats 'coz deep sleep well is activated. In this scenario laptop remains on DSW state and not S5 stage by default. When you press power button, it will get back to S5 state and then only 3/5V ALW will be generated. This is done to save power. However, 3/5V does get generated on most boards at the beginning (when consumption is say 0.015ma) for a very brief interval and then it will go to DSW stage.
            • ipn00tic
              Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
              by ipn00tic
              Hello everybody,
              I'm learning alone at home (with you) of course.
              I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
              The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
              I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
              The VCC_GT power...
              03-01-2024, 05:32 AM
            • jermac0711
              ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
              by jermac0711
              Brand : Acer
              MOBO: PEW71 LA-5894P
              Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
              I hope you guys can shed some light. Thank you so much in advance.
              12-17-2024, 08:25 PM
            • Kshi
              Acer a515-52g no power 19v not passing through first mosfet
              by Kshi
              I purchased this laptop from fb marketplace
              and the previous tech jumped 1st mosfet. maybe it got fix, then time comes by jumpering fried the charging ic?
              tried to change mosfet but it does nothing 19v is not passing through 1st mosfet
              tried to jumper again, I got 5vlp and 3vlp but 5valw and 3valw is missing
              I suspect that the charging ic is bad? If so how do i test if it is bad.
              Cant see any short or corrosions on board
              schematic and brd view attached below
              07-25-2025, 01:13 AM
            • vexarvf1s
              Acer: No power after first MOSFET no short? Looking for guidance.
              by vexarvf1s
              Looking for guidance in tracking down missing main power rail.
              I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
              First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
              So checked for voltage on the gate of the first MOSFET and...
              05-13-2023, 07:55 AM
            • samaelvonhell
              Acer Nitro 16 AN16-41 motherboard: DAZGUMB1AD0 turns off after 60 seconds
              by samaelvonhell
              Hello. Could anyone help me with that problem.
              Laptop model: Acer Nitro 16 AN16-41
              It had liquid contact and owner dried it up. Dried it so hard that keyboard is all wavy...
              I've found one drop on motherboard near B+ capacitor, it wasn't short.
              But motherboard works exactly 60 seconds and turns it self off. Not overheating just exactly 60 seconds. Normally I would say its ME Region problem, but CPU is AMD...
              In case im attaching BIOS backup
              08-01-2024, 08:11 AM
