Nitro 5 AN515-51 - Burned KBC and regulator - LA-911P
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Re: Nitro 5 AN515-51 - Burned KBC and regulator - LA-911P
    Originally posted by SMDFlea
    Yes maybe. Are you sure theres no bridged pins on the SIO .Check for corrosion or liquid damage on RB13 and JHS1 pin 2 LID_SW#
    No, SIO pins have been triple checked all good.
    I could try a different SIO just to be sure, but I dont have any spare
    Machine is super clean not a minor sign of corrosion.
    Only thing I could see were the 2 burned ICs I replaced
    lll doublecheck
    • magneh
      • Apr 2014
      • 588
      • Portugal
      Double checked no corrosion or any liquid damage whatsoever.
      Only those 2 burned ICs as I referred.
      Since the SIO was burned, and that I can hear the clicking sound at the PCH, could this indicate a bad chip?
      Power consumption is 2ma - 23ma - 2 ma and cycling
      This 23 mA peak matches the clicking sound on the PCH.
      I suppose I could try to lift PCH with hot air (not going to be easy) and check if cycling goes away and if+3VLP_EC stabilizes?
      If anyone has some suggestions, I will be willing to try.
      If not, RIP
      Thanks!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If you try to lift the PCH with hot air, you are surely going to damage the mb with broken tracks on pcb. You need a bga machine for the purpose.
        • Sametbey
          • Jan 2021
          • 229
          • Turkey
          Have you tried dividing JP2 and giving 3v to 3VLP_EC? how many mA it draws. Are there any heated parts? When the PU401 receives a 12 pin ENB signal, it will start to output 3VLP. Not only 3.3v circuitry but other (audio, ethernet, cardreader, PCH) may be problematic.
          I'm not happy to be so strong. because it's not humanly
          • magneh
            • Apr 2014
            • 588
            • Portugal
            Well, with some patience and good preheating , I think its doable.
            its not a huge BGA , so I think it could work
            But yes, BGA machine is the right away to do it, no doubt.
            It would just be an option to check if the +3VEC would be stable without it
            • magneh
              • Apr 2014
              • 588
              • Portugal
              #26
              Yeah, if I open JP2 and inject 3v, I get 10mA , so nothing heating up or any type of short.
              With JP2 closed, I get 72ma , so nothing wrong IMO
              ethernet 3.3V have been disconnected and still the same.
              Maybe I can try to remove audio and card reader IC or anything that delivers the 3.3V
              As I hear the PCH clicking, and since SIO was burned, maybe it damaged the PCH ...
              • magneh
                • Apr 2014
                • 588
                • Portugal
                #27
                Does anyone know how I can find what IC is this? PU401?
                Cant find it by the letters on it...AWV701
                I removed the SIO, and 3.3V EC is stable now.
                But this IC should output 3VALW and its not... and its also responsible for 3V and 5V rails activated by the SIO
                Pin 11 EN is present.
                So I think this IC could be the responsible for this, but would need a datasheet to check
                Any idea?
                • khaahk
                  • Dec 2013
                  • 766
                  • Estonia
                  #28
                  Datasheet for SY8286B is not available ("A" is but there are differences). But yes it is responsible for 3V, the smps output should start after enable signal on pin 12 is present. (should come from SIO which you have removed).
                  • magneh
                    • Apr 2014
                    • 588
                    • Portugal
                    #29
                    Thanks, sad theres no datasheet
                    I have the PIN 11 enable at ENLDO_3V5V
                    Should this be enough to get output at pin 14 +3VALWP?
                    or needs to be enabled at pin12?
                    Just trying to be sure that I should have +3VALWP present without the SIO or not
                    • khaahk
                      • Dec 2013
                      • 766
                      • Estonia
                      #30
                      SIO gives enable signal to pin 12 for +3VALWP to start.
                      • guardiny
                        • Nov 2021
                        • turkey
                        #31
                        I have same problem in mines too... Did you solved ?
                        • leovalpo
                          • May 2014
                          • 12
                          • chile
                          #32
                          La nomenclatura “+3VLP” en un diagrama esquemático se refiere a una fuente de alimentación de 3.3 voltios. El sufijo “LP” indica que la fuente de alimentación es de baja potencia (Low Power).
                          Mirando el esquema, esta señal es un voltaje que se crea para probar la corriente y (para este caso) alimentar el SIO (EC) y encenderlo.
                          El problema entonces, es que no se está superando esa prueba, por ende el SIO (EC) no se encenderá.
                          Es muy posible que el SIO (EC) esté con una falla (bueno, el colega dice que SIO estaba dañado y que se oye un sonido en el PCH, entonces este último también debe haberse dañado. Recordemos que el SIO (EC) es un circuito de protecciópn general de la Placa Lógica, o mejor dicho es el PMU (Unidad de Energía altamente integrada, regulador de voltaje multicanal).
                          Para finalizar, y para entender mejor, suponiendo que el PCH está OK, si no hay +3VLP, entonces (para este caso) no hay encendido de SIO (EC o KBC como le dicen algunos), y considerando que todo el resto de fuentes o POWER RAIL no están en corto, es muy seguro que solo esté dañado el SIO (EC o PMU).
                          Por favor, si estoy errado, corríjanme.
                          Gracias por leerme.
                          Atte.,
                          Notebook Centro® CHILE
                          The nomenclature “+3VLP” on a schematic diagram refers to a 3.3 volt power supply. The “LP” suffix indicates that the power supply is low power.
                          Looking at the schematic, this signal is a voltage that is created to test the current and (for this case) power the SIO (EC) and turn it on.
                          The problem then is that this test is not being passed, therefore the SIO (EC) will not turn on.
                          It is very possible that the SIO (EC) is faulty (well, the colleague says that the SIO was damaged and that there is a sound in the PCH, so the latter must also have been damaged. Let us remember that the SIO (EC) is a general protection circuit of the Logic Board, or rather it is the PMU (highly integrated Power Unit, multi-channel voltage regulator).
                          Finally, and to better understand, assuming that the PCH is OK, if there is no +3VLP, then (for this case) there is no SIO turning on (EC or KBC as some call it), and considering that all other sources or POWER RAIL are not shorted, it is very likely that only the SIO (EC or PMU) is damaged.
                          Please, if I am wrong, correct me.
                          Thanks for reading me.
                            ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                            This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-12-2024, 03:28 PM
                            ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                            This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
                            Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti,...
                            09-07-2024, 03:10 AM
