Nitro 5 AN515-51 - Burned KBC and regulator - LA-911P
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Hello!
    I have this laptop on my bench, dead no power, no leds.
    Checked the MB , and found 2 burned components with a hole on them, KBC and battery charger IC PU301 (BQ24781)
    No liquid damage.
    Replaced both components, still no power.
    Found that +3VLP_EC is oscillating and +19VB same thing.
    When I open JP2 to isolate, +3VLP is 3.3V and +19VB is 19V stable
    No short in +3VLP_EC and all KBC pins measure ok. no shorts
    I hear a clicking sound ,think it comes from the chipset, and this clicking sound is cycling matching the cycling consummation on the PSU, 2-3mA, 25mA,2-3mA and so on. Sometimes I see CC light blinking shortly.
    Measured caps on the chipset, all values seem OK, nothing shorted.
    Same thing around the chipset itself, all values seem OK, no shorted lines.
    All coils OK, no shorts found also.
    No voltages present, except in PL301 I have 0.21V (battery coil)
    What do you guys think? Bad chipset?
    Any other test or measurements I could do to confirm this?
    KBC chip was not programmed, but I suppose if that was the issue, +3VEC would still be stable.
    Let me know if you have other suggestions for this case.
    Thank you!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Nitro 5 AN515-51 - Burned KBC and regulator - LA-911P
    Known good AC adapter of correct power rating?
    If yes measure exact resistance to ground on all the large inductors.
      • 20707
      Press SW2 in .
      • magneh
        • Apr 2014
        • 588
        • Portugal
        Salut Piernov.
        using my bench power supply
        No shorts in any inductors.
        • magneh
          • Apr 2014
          • 588
          • Portugal
          Originally posted by SMDFlea
          Press SW2 in .
          Nothing changes.
          Battery is not plugged in for info
          • khaahk
            • Dec 2013
            • 759
            • Estonia
            Resistances after UQ1 at J5 and J6?
              • 20707
              Can you remove UL1 and RL2 then check if +3VLP_EC is stable with JP2 soldered.
              • magneh
                • Apr 2014
                • 588
                • Portugal
                Hello!
                So here's the resistance I have.
                J5 - 12.3k ohm
                J6 - 490k ohm
                • khaahk
                  • Dec 2013
                  • 759
                  • Estonia
                  Originally posted by magneh
                  Hello!
                  J5 - 12.3k ohm
                  J6 - 490k ohm
                  Seems fine.
                  Does the SMPS part of the 3v and 5v try to start? Do you see some activity on PL402, PL404? If you have, use an oscilloscope.
                  • magneh
                    • Apr 2014
                    • 588
                    • Portugal
                    UL1 is no stuff
                    Removed RL2 and +3VLP_EC is still flickering 0-2V something like this.too fast to catch on multimeter.
                    • magneh
                      • Apr 2014
                      • 588
                      • Portugal
                      Seems fine.
                      No,nothing I can see with the multimeter.
                      SIO is not releasing the Enables for 3v and 5v, as the +3VLP_EC line that powers up the SIO is not stable...
                      this is what I could understand so far...just not seeing what could cause this...probably the chipset, but not sure
                        • 20707
                        UL1 is no stuff
                        Yes UL1 is no stuff .Ok remove LB1 and check +3VLP_EC again
                        • magneh
                          • Apr 2014
                          • 588
                          • Portugal
                          Still the same after removing LB1
                          • khaahk
                            • Dec 2013
                            • 759
                            • Estonia
                            It might be happening so fast that it is impossible to catch with multimeter.
                            Just in case check for low resistance on RTCVCC on DH3
                              • 20707
                              Check RB1,if thats ok i`m out of ideas
                              • magneh
                                • Apr 2014
                                • 588
                                • Portugal
                                Very high resistance. 0.5 in diode mode
                                • magneh
                                  • Apr 2014
                                  • 588
                                  • Portugal
                                  Yeah Im getting 75k so should be fine.
                                  Guess I cant also not figure this one out
                                    • 20707
                                    Its 100K in the schematic 100K_0402_1%
                                    • magneh
                                      • Apr 2014
                                      • 588
                                      • Portugal
                                      yeah but measured in circuit,so I believe if i remove and mesure it will be 100k
                                        • 20707
                                        Yes maybe. Are you sure theres no bridged pins on the SIO .Check for corrosion or liquid damage on RB13 and JHS1 pin 2 LID_SW#
                                          ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:28 PM
                                          ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...
                                          09-07-2024, 03:10 AM
