Hi Friends
So i have today a XPS9560 laptop with LA-E331P motherboard i7 CPU.
There were some corrosion around the charging chip BQ777. I cleaned the corroded component with ultrasonic. And then tested all the components within the corroded area. Replaced 2 resistors as they had wrong readings and then the laprop powered on. The original laptop battery were shorted and the battery fuse were blowen (inside battery circuit) so i replaced the battery as well.
Now the batttery is charging normally. But the only wiered issue i am facing is that when the charger is connected (with or without battery) the laptop shuts downd during windows loading (no restarting but completely shuts down). But it does not shutdows in bios. Only shuts down during loading windows. It also shuts down when booting from usb to install fresh windows. However, when only the battery is connected (without the charger), the laptop is completely fine with excellent working performance.
I have tried couple of clean bioses but the same issue. So any suggestions or if anyone else has experianced the same issue and resolved it please share.
Just to added, the charger is dell original and is 130w and working just fine.
