No output through lvds, only hdmi
  • liquidzorch
    • Oct 2016
    • 134
    • mexico
    Hello. A client brought in a lenovo g480 for repair, it would not turn on. I flashed the bios with a clean on found here, and it now turns on. Now there is an issue with the screen. The screen it had seemed to have been removed once before (the laptop has an unknown backround), this screen had an image but all scrambled, you couldn't make out anything on the screen. So I told the client (who bought the laptop as is) that I could get it to boot but he would have to change the screen and/or lvds cable. Now he came back with a new screen and a new lvds cable and it has no image, it just lights up black. It DOES however output a perfect image through HDMI to my tv.
    I have tried flashing other bios files, like a g580 file that I found here, and a confirmed working g480 bios also from here. All power up and send image through HDMI, but get no image on laptop screen. I have tried my own lcd screen, just to make sure, with old and new lvds cable, all do the same thing.
    Any ideas?
    ps. The computer has no operating system, I am only using post and bios settings screen. This should have no affect on the output
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: No output through lvds, only hdmi
    Schematic is available. Why not check LVDS pin voltage and find out what is missing??
    • liquidzorch
      • Oct 2016
      • 134
      • mexico
      Every signal pin has a voltage. Most are around 3.3v, others around 1.5v. Do pins that have "clk" need to have a clocl on them? With an oscilloscope, two of the clk pins are stable at 3.3v.
        • 20763
        Do you know what part number the screen with the scrambled image was,and the part number of the new screen.It should be similar to LTN140AT26L01
        • liquidzorch
          • Oct 2016
          • 134
          • mexico
          Part number LTN140AT26, it gives a black screen (backlight on).
          One that gives a scrambled output is: LTN140AT07.
          Both work great on a Compaq CQ40 that I have here.
          And as for the first one it had, I do not know what the part number was, but it also had a scrambled output.
            • 20763
            You can try and flash a lenovo EDID dump to the LTN140AT26 .The EDID is stored on a small 8 pin chip on the PCB. See post #63 here for the dump - https://www.badcaps.net/forum/showth...t=74729&page=4
            • liquidzorch
              • Oct 2016
              • 134
              • mexico
              Thanks. Would it be this if the screen works correctly in another laptop? I'm asking since I would have to buy a programmer just to try and flash it.
                • 20763
                On some older ibm/lenovos the EDID is modified to whitelist them.Don`t you have an SPI programmer ?
                • liquidzorch
                  • Oct 2016
                  • 134
                  • mexico
                  I use a raspberry pi. I'll check to see if flashrom is compatible
                  • liquidzorch
                    • Oct 2016
                    • 134
                    • mexico
                    I have not found info on flashing the EDID with a raspberry pi. But I did find a LTN140AT26 l01 on another lenovo, isntalled it, but still got a black screen, so I would imagine it isn't an EDID problem.
                    Does the bios do any serial checks with the ec or anything? The bios files I have flashed have been as is, just downloaded the files from here and flashed. They all have worked for HDMI output.
                    Another issue, if I try to update the bios from windows using the original files from lenovo, When I press flash in the pheonix program, the progress bar gets to about 1/4 the way quickly and the just disappears with no message. I does not have a battery, but I would image if it was that then an error message should appear. I don't know if something else is stopping the update.
                    PS: the bios that is corrput was version 62cn41ww, and I flashed a 62cn44ww (currently on it). And I have tried a 62cn34ww. The ec version is 62ec30ww (havent touched that).
                      • 20763
                      Maybe the problem is with the PCH, not sure. Post a link to the schematic. The phoenix flasher might have a command line switch to bypass the battery check.
                      • liquidzorch
                        • Oct 2016
                        • 134
                        • mexico
                        I got the schematic from here:
                        https://forum.laboneinside.com/viewt...oogle_vignette
                        I was thinking PCH but I don't know how to confirm it.
                        • liquidzorch
                          • Oct 2016
                          • 134
                          • mexico
                          Edited, useless information about lvd_ddc lines not communicating.
                          • liquidzorch
                            • Oct 2016
                            • 134
                            • mexico
                            Never mind. I see that there is communication occurring on the lvd_ddc lines during the first second of turning on.
                            Another symptom. While in windows, if I booted with the lcd plugged in, but HDMI off. I can never get HDMI to work, it never switches. The same if I boot with HDMI, and later unplug the HDMI cable, the lcd does not turn on.
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                            • speedtime07
                              i life zed air cx5 no image on screen
                              by speedtime07
                              hi everyone ,
                              There is an image on the external computer screen ,
                              flexi cable test ok - screen test ok -
                              What alternative should I look for?
                              thank you for your support​
                              04-10-2025, 06:24 AM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • cashkennedy
                              Onn tablet screen
                              by cashkennedy
                              An ebay seller shipped me this broken tablet by mistake, and so I got my money back, but there are a decent amount of these seemingly in perfect shape but with screen issues (this tablet was clearly a return that had never been used or setup, so I don't think any physical damage occurred, also is a kids model so large bumpers on cover that isn't in picture) Is this a loose lvds cable or anything repairable beyond replacing the screen which would come with its own integrated tcon which is maybe where the problem would be?
                              The power on screens just exhibit the sideways smear, once...
                              07-14-2025, 06:12 PM
