What's the difference between KBC and SIO?
  • dan1200rr
    • Apr 2014
    • 9
    • Poland
    on laptop motherboard we can find KBC (keyboard controller) and his replacement called SIO (most on Dell motherboards).
    Whats are the difference between them.
    Best regards
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: What's the difference between KBC and SIO?
    https://www.badcaps.net/forum/showpo...19&postcount=5
    Just to make things clear, what people call "startup chip", "multicontroller", "Keyboard Controller"/"KBC", "Super I/O"/"SIO", "Embedded Controller"/"EC" is essentially the same thing on modern PC.
    I prefer calling it the "EC" (or Embedded Controller) when talking about a laptop, because it does a lot of various things and it is programmable. On a laptop, it'll be the ITE ITxxxx, ENE KBCxxxx, SMSC MECxxxx chip. The SMC on Macbooks has a similar role, although it doesn't have a keyboard controller in it. It's a microcontroller that has its own firmware and executes it as soon as it receives power (and its reset signal is deasserted), independent from the CPU.
    On desktops (mostly low/mid range boards), it does less things and is usually not programmable, Winbond or ITE IT871x/872x chips are common. On older board it also had a floppy disk controller in it.
    • dan1200rr
      • Apr 2014
      • 9
      • Poland
      According to this, the main difference is just lack of keyboard controller in SIO.
      Any major difference more?
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • eenee
        bios txe region y116te_e_glk
        by eenee
        It's possibly a Chinese offbrand laptop that uses a generic series of motherboards called y116te. It has no image.All power rails are working. No bios dumps could be found on the internet. Tried similar bios from this thread. No difference. I wanna try cleaning the TXE region of the bios but cleaning TXE region seems too advanced for my skills. Please help clean the TXE region from this dump ...
        05-15-2024, 02:39 AM
      • qwerty99
        Xbox 1.6 Motherboards and Polymer Capacitors
        by qwerty99
        Hello!
        I need to change the capacitors on my three original Xboxes.
        Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
        The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
        The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
        I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
        06-26-2022, 12:53 AM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
      • Foetuss
        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
        by Foetuss
        Hi all
        Hope this is in the correct place.
        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
        Could use some double checking to see if I'm not doing something stupid .
        Pictures of the boards are attached.
        What I will be replacing with what : (planned)
        Soltek Golden ::
        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
        01-18-2025, 11:44 AM
