What's the difference between KBC and SIO?
  • dan1200rr
    • Apr 2014
    • 9
    • Poland
    on laptop motherboard we can find KBC (keyboard controller) and his replacement called SIO (most on Dell motherboards).
    Whats are the difference between them.
    Best regards
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: What's the difference between KBC and SIO?
    https://www.badcaps.net/forum/showpo...19&postcount=5
    Just to make things clear, what people call "startup chip", "multicontroller", "Keyboard Controller"/"KBC", "Super I/O"/"SIO", "Embedded Controller"/"EC" is essentially the same thing on modern PC.
    I prefer calling it the "EC" (or Embedded Controller) when talking about a laptop, because it does a lot of various things and it is programmable. On a laptop, it'll be the ITE ITxxxx, ENE KBCxxxx, SMSC MECxxxx chip. The SMC on Macbooks has a similar role, although it doesn't have a keyboard controller in it. It's a microcontroller that has its own firmware and executes it as soon as it receives power (and its reset signal is deasserted), independent from the CPU.
    On desktops (mostly low/mid range boards), it does less things and is usually not programmable, Winbond or ITE IT871x/872x chips are common. On older board it also had a floppy disk controller in it.
    • dan1200rr
      • Apr 2014
      • 9
      • Poland
      According to this, the main difference is just lack of keyboard controller in SIO.
      Any major difference more?
      • eenee
        bios txe region y116te_e_glk
        by eenee
        It's possibly a Chinese offbrand laptop that uses a generic series of motherboards called y116te. It has no image.All power rails are working. No bios dumps could be found on the internet. Tried similar bios from this thread. No difference. I wanna try cleaning the TXE region of the bios but cleaning TXE region seems too advanced for my skills. Please help clean the TXE region from this dump ...
        05-15-2024, 02:39 AM
      • qwerty99
        Xbox 1.6 Motherboards and Polymer Capacitors
        by qwerty99
        Hello!
        I need to change the capacitors on my three original Xboxes.
        Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
        The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
        The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
        I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
        06-26-2022, 12:53 AM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • Foetuss
        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
        by Foetuss
        Hi all
        Hope this is in the correct place.
        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
        Could use some double checking to see if I'm not doing something stupid .
        Pictures of the boards are attached.
        What I will be replacing with what : (planned)
        Soltek Golden ::
        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
        01-18-2025, 11:44 AM
      • Jackching
        What is the end called on this wire?
        by Jackching
        Anyone know what the end is called on this gps wire?
        https://www.amazon.ca/dp/B01N3QHLDE
        I see you can buy gps antennas that have wires exposed and no cable ends. I need this end for my hondex plotter.
        08-05-2024, 11:53 AM
