ASUS ROG G751JY randomly shuts down
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    ASUS ROG G751JY randomly shuts down. i cannot trace what is wrong. no voltage change or shortage. only i noticed that chipset ic is very hot. i put small heatsink on it but after few minutes it is hot for touch
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: ASUS ROG G751JY randomly shuts down
    Try cleaning bios ME. On older models random shutdowns was usually caused by a bad podlizer cap.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3630
      • slovakia
      what is podlizer cap?
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        typo, sorry. I meant Proadlizer Capacitor (NEC TOKIN) https://parts4laptops.eu/en/other-el...citor-new.html. But I doubt your motherboard has this.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I've seen many ROGS and most of them has issues with PCH. However, that may/may not be the case here.
          • Smoxx
            • Jun 2019
            • 36
            • Argentina
            ROGs are well known for being shipped with voltages set extremely high in BIOS factory defaults and undervolting VCORE may solve auto shutdown issues most of the time. Not sure if this is the case here but it is one of the fixes you could try.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3630
              • slovakia
              but full load tests will not show it as overheating?
              • Smoxx
                • Jun 2019
                • 36
                • Argentina
                Are you able to run and complete full load tests without shutdown? If so, then overvolting may not be the issue.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  Did you by any chance check if the cooling fins are clogged?
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3630
                    • slovakia
                    cooling is not a problem. i run it by full load on gpu and cpu and it goes without problem. shut downs comess looks like randomly
                    sometimes i have problem with running two hdd. so i think maybe chipset have cracked balls under it
                    i have acer that have this problems , but it was the proadlizer cap
                    • paulo66
                      • Dec 2020
                      • 88
                      • Portugal
                      Probably a long shot but the larger capacitor could be acting up like the Nec Tokin cap. Check for AC ripple across it.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3630
                        • slovakia
                        ripple is 55-77mV
                        on gpu is ripple 25-55mV
                        • paulo66
                          • Dec 2020
                          • 88
                          • Portugal
                          AC mV? Isn´t that noisy for Vcore?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3630
                            • slovakia
                            today the first time after shut down i cannot start it. VIN was low. but after minute it start again. so i just jump first two mosfets and after that, no shutdown.
