HP G6 MB R13 Battery not charging
  • Caimano
    • Nov 2020
    • 54
    • Italia
    Hi, I am working on a HP Pavilion G6 laptop with R13 motherboard and Intel I5 second generation processor + discrete GPU.
    Initial problem was no boot and no poweron led..
    Found that +12VALW generated by PU2 was shorted to ground by PC67.
    Removed capacitor and power on led turned on. Also noticed that the area around 2nd mosfet PQ52 was light brown and actually the mosfet was shorted
    Replaced mosfet. Laptopo turns on and boots windows fine. reinstalled Windows and updated bios to last version.
    Unfortunately found that there is a problem with battery charging: led turns orange regularly but battery voltage remains the same. Checked different batteries and power supplies (working on a similar G62 laptop). Windows CPU ID utility correctly shows battery voltages, statistics and wear level ( so connection with the battery seems to be working), but no charging occours.
    Charging IC is PU9 OZ8681 (qfn 16 but I could not find any datasheet).
    Here are the voltages of the most relevant pins :
    pin 1 - VAC =19V
    pin 9 - ACIN = 3,3V (when charger connected)
    pin 12 - BST = 16,91V
    pin 13 - HDR =11,28V
    pin 14 - LX = 11,28V (the battery voltage)
    pin 15 - VDDP = 5,8V
    pin 16 - LDR = 0V
    Tested resistance on the 2 feedback lines (between pin 2 and 3, and between 4 and 5 = around 20ohms each which sounds good to me
    Voltages on the battery connectors:
    1 - B+ =11,28V
    2 - B+ =11,28V
    3 -SMD =3,3V
    4 - SMC = 3,3V
    5- not connected
    6 BTEMP_MBAT = 1,69V
    7 and 8 GND
    Replaced PU9, PQ30, PQ29 (battery charger chip and the 2 driving mosfet which tested good). Replaced also PQ35 but problem remains.
    Who tells the charging chip to start charging and how (EC CHIP?)?
    Any help or suggestion is highly appreciated. Thanks
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Julian Bailey
    HP ProBook 445 G8 Battery not charging
    by Julian Bailey
    Hi all
    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
    I have gone around the board with a MM and cant find anything
    Windows shows the battery fine,...
    10-11-2024, 10:34 AM
  • Shinju
    Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
    by Shinju
    Hey All!
    Long time forum member here with a problematic laptop issue!
    I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
    The laptop would not power on with the new battery installed without the power supply being plugged in.
    When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
    TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
    10-20-2021, 04:58 PM
  • Iherduleikgemz
    Asus FX505DY - Battery not charging - BQ24780S
    by Iherduleikgemz
    Hello everyone
    I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
    I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
    01-13-2025, 03:54 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
