HP 250 G7 - windows clean install
  • zmeutz
    • Nov 2016
    • 84
    How can I install windows 10 on HP 250 G7?
    In BIOS I can't disable secure boot
    with rufus I tried
    MBR Partition scheme for bios or uefi
    MBR Partition scheme uefi
    GPT Partition scheme uefi
    works on GPT but it return an error
    An unexpected error has occured
    0xc0000017
    enter try again
    f8 startup settings
    esc uefi firmware settings
    How to access Advanced BIOS Settings?
    Anyone has this problem?
  • pecrie
    • Nov 2011
    • 182
    Re: HP 250 G7 - windows clean install
    I cannot say what is the problem.
    But maybe this can help.
    What version of Win10 you want to install ?
    Have you (re-) flashed the bios chip.If , yes , with the latest firmware ?
    For 64 bit systems ?
    For Win10 64 bit , it is adviced to use a 16 GB usb stick to install.
    What version of Rufus did you use ?For me Rufus 3.3 works oke.
    What is the message when you get the error ?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      stick can be 8GB. why using any other tool when u have Windows creation tool that downloads newest version and make botable usb
      clean disk in diskpart and use that usb. no need to disable secure boot
      • m3vuv
        getting an hp elitebook 8730w to work with a gpt drive with uefi
        by m3vuv
        Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
        07-15-2024, 10:15 AM
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • GuiTi
        Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
        by GuiTi
        Hey everyone!
        I need help with my Lenovo Chromebook 100e Gen 3.
        Here are the details:
        • Motherboard: LA-L131P
        • MFG Date: 2022/01/07
        • MTM: 82J80001BR
        • MO: MPNXB2103001
        • Factory ID: LI123
        I bought a new Winbond 25Q128FVSG chip.
        The chip currently on the board is the same model but with different ending letters.
        I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
        The Chromebook is Google account locked, and I’ve already tried everything.
        I understand that I need to replace or...
        10-14-2025, 08:41 AM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • OscarAV
        Copying/getting BIOS content problem.
        by OscarAV
        I am trying to copy the BIOS content, since a user replied to my post in the laptop repair section, and told me that this is a good starting point on my situation. I CAME here, to the BIOS section, and read the guides there, but just to be sure... I downloaded two files, a BIOS configuration utility, sp143621.exe, and a HP UEFI Support Environment, sp61101.exe.
        When I run the configuration utility on the cmd,
        It gives me an error, system not supported, unable to connect to HP WMI namespace:'root\HP'
        Then, I tried to install HP UEFI Support...
        09-26-2024, 08:46 AM
