A1466 820-0165-A No power
  • mon2
    • 14020
    Hi. Have an A1466 820-0165-A with a black screen. Attached magsafe charger, the light goes green. No fan spin.
    See 8v6 rail; 3v3 rail; no 5v0 (7A) rail. Many other rails also missing.
    Proceeded to remove wifi; SSD cards - no difference.
    Then proceeded to remove the flat cable between the audio board (820-3455-A) and the main logic board. Bingo! Fan spin.
    Proceeded to add back the SSD & wifi card - still ok on fan spin.
    Attached the lvds cable - have video and the macbook booted to the desktop.
    If we attach the audio board with the flex connector - the system acts dead again.
    The trackpad had some hints of liquid damage - cleaned with alcohol and appears to work ok. The power button is still not working correctly from what we can tell. Need to check online videos but is this keyboard with rivets? Will study the schematics on how the on/off power button functions.
    Are the audio boards serviceable? See some potted parts on this tiny board (has the magsafe + USB + audio jack + audio codec?).
    They are pretty pricey on the websites.
    Welcome any suggestions.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: A1466 820-0165-A No power
    The Keyboard should be screw based if I am not mistaken. Rivets last time I checked are in the Retina models from 2012 and above. The IO board on these are fairly cheap on eBay have you considered looking for them there?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • zpi
      • Feb 2018
      • 132
      • Lithuania
      On off: smc_onoff 3.4v when you press power button you short it to ground an macbook turns on. You keep shorting, macbook turns off.
      Inspect DCIN board and ribbon to liquid damge. Probably just bad dcin board or ribbon. Buy them and change them.
      • mon2
        • 14020
        Thank you both for your replies.
        With incredible luck, had a spare but brand new trackpad for this model from China. The owner was complaining about the track pad before. The trackpad connector was heavily corroded and the hot air with fresh flux did not help at all. Rather, warped the black plastic blade connector a bit.
        The replacement trackpad works perfectly and now the keyboard on/off is also working properly.
        The fan is on full speed - is that normal?
        The audio board still has the complex ribbon cable not connected. The board does not appear to have any liquid damage. Ebay is around $50-$80 USD for this small board; Aliexpress is about $30 USD + shipping. Amazon is $100 (cad). Pricey boards.
        The complex ribbon cable and pins look brand new and still shiny and gold plated.
        The computer is booting fine but we have no audio chime out of the system. Guessing the audio codec on this board is the sound generator?
        • piernov
          • Jan 2016
          • 4435
          • France
          Genuine Apple Magsafe2?
          • mon2
            • 14020
            Hi. Yes. Original magsafe adapter. Have a new audio board and new interface ribbon cable on order now from China.
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              Fan will spin if dcin board is not connected properly, also you will not have chime or any other sound ond board. So all symptoms shows bad dcin board.
              Till new parts arrives you can start diagnostics by pressing D while macbook boots up. Then you can see if there are other errors.
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
                Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-07-2024, 02:20 AM
                Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 09:30 PM
                Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 07:50 PM
