Dell XPS 13 9360 No charge
    • 20795
    Re: Dell XPS 13 9360 No charge
    Do you have any dell donor boards,if so what motherboard part numbers are they.
    • Andreasbest
      • Aug 2014
      • 1163
      • Hellas ( Greece )
      i got:
      QALA1 (from Dell E6530)
      QAL81 (from Dell E6430)
      FX3MC (from Inspiron 15)
      and several from very old Latitude D520 but i don't think they got anything like this.
        • 20795
        None of those will do. I found some on ali ,if you can wait a few weeks for delivery https://www.aliexpress.com/item/4000861764202.html
        • Andreasbest
          • Aug 2014
          • 1163
          • Hellas ( Greece )
          Good, thank you very much for everything!
          • xrated
            • Dec 2021
            • Deutschland
            This seems to be a common problem on XPS13/15 series. I got the same problem, is this the affected part?
            • Andreasbest
              • Aug 2014
              • 1163
              • Hellas ( Greece )
              #26
              Yes exactly!
              • xrated
                • Dec 2021
                • Deutschland
                #27
                what soldering tip and temperature is needed for this? i never did any SMD soldering and need practice
                got an old ERSA MS8000 soldering station
                  • 20795
                  Originally posted by Andreasbest
                  Yes exactly!
                  These TVS diodes have been a problem for me too.Anyway i`ve found a TVS cross reference at baidu and copied the part i could see to a jpeg.
                  https://wenku.baidu.com/view/24ae99f...2396893e2.html
                  If the cross reference is accurate then it lists parts from semtech,protek,NXP and vishay.You can find the datasheets and see for yourself if you think one of them will be ok as a replacement. Some of those sites have a cross reference search (xref) so you can further xref each part number.
                  Edit: Found an older xref pdf from valorstat semi, it lists these 3 uClamp0501H, PESD5V0L1UB, AZ5125-01H
                  PESD5V0L1UB toshiba xref: https://toshiba.semicon-storage.com/...SD5V0L1UB.html
                  uClamp0501H diodes Inc xref https://www.diodes.com/design/tools/...terForm=Search
                  • mgrharry
                    • Sep 2016
                    • 211
                    • usa
                    #29
                    Sorry to jump on an old thread here, but I have come across a very similar issue with a small twist. The TVS diode, PD102, and burned one side of the trace. See pic below. I did find what I think is a compatible donor from a Dell XPS 9560 board, 2nd pic. From what's left of the trace, it appears that it went to both the resistor marked #1 and cap marked #2. So ISTM I could attach a new tvs diode connecting to what's left of the trace at #2 and run a small jump from there to #1, is that right?
                    As usual thanks for your suggestions.
                    • Andreasbest
                      • Aug 2014
                      • 1163
                      • Hellas ( Greece )
                      #30
                      Seems right to me, take a look at schematics to be 100% sure.
                      • Pastorovich
                        • May 2023
                        To me that looks like some residue/gunk/whatever. Is that really burned? Did you try cleaning it with IPA or nail polish remover (careful of course)?
                        • nickstyle
                          • Aug 2022
                          • 42
                          • United Kingdom
                          #32
                          Hi,i bought a xps9350 and i have the same problem
                          Is not charging the battery with dc Dell charger but is charging with usb c charger
                          I checked the PD102 and seems to be ok
                          PR103 also is good 33ohm
                          i do have 3,3v also on PQ101
                          So what ele can be?
                          I supose is not the BQ chip as log is charging with usb c charger
                          • mon2
                            • Dec 2019
                            • 14120
                            Confirm if the bios reports the correct stats of the attached power adapter.
                            Is the power adapter of the proper ratings for this logic board?
                            • nickstyle
                              • Aug 2022
                              • 42
                              • United Kingdom
                              #34
                              The bios says unknown power adapter. I do use a 45W Dell adapter.
                              • mon2
                                • Dec 2019
                                • 14120
                                Measure the voltage to ground of each pin on pq100. Post each measurement.
                                • nickstyle
                                  • Aug 2022
                                  • 42
                                  • United Kingdom
                                  #36
                                  I have attached a pic with voltages
                                  So i have 5,3.3 and 3.3V
                                  Thank you
                                  • mon2
                                    • Dec 2019
                                    • 14120
                                    These are good voltage measurements. The gate voltage is higher than source / drain voltage so mosfet should be enabled to pass through the single wire communication traffic.
                                    Remove all power. Meter in diode mode. Short the meter probes and the meter should tone beep. Touch one probe to one of the mosfet pins at 3v3 in the last measurement. No power to the board. Touch other meter probe to the dc adapter connector on the logic board used for the PSID. Do you hear a tone beep? If not, test the other mosfet pin.
                                    This is to confirm the fault is not in the power adapter connector. One combination must tone beep. If yes, consider to remove this same mosfet and bypass the source and drain pins with a short with a wire or solder blob. There should be empty pcb pads for this bypass but remove the mosfet if testing this way.
                                    This bypass is to rule out the mosfet as being defective. Many cases on this forum that confirm the mosfet as being defective.
                                    • nickstyle
                                      • Aug 2022
                                      • 42
                                      • United Kingdom
                                      #38
                                      Sorry for the trouble, it was the stupid power adapter. I ordered another adapter and is charging . The first 1 bought is second hand as i wanted to buy an original Dell
                                      • Bigdaddy81
                                        • Mar 2025
                                        Hello my name is Paul I'm new to all of this but learning daily I've got same problem but it looks like I've got a hole in the little black resister right behind the port cloud this be my problem
                                          DELL XPS 9360 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9360 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9360 boardview and 9360 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9360 Notebook...
                                          09-06-2024, 04:00 PM
                                        • dsuli
                                          Dell XPS 9360 LA-D841P REV 3.0 (A02) BIOS and BIOS CHIP
                                          by dsuli
                                          I am having an issue with my xps 9360, where the BIOS updates fine, but then freezes as it tries to update the ME region.. it just gets permanently stuck (attached).
                                          I think because of this, I keep getting this annoying popup whenever I start the laptop about an issue with my thunderbolt dock or something (even when there is nothing connected to the laptop).
                                          Anyway, I would like to try to flash the ME region manually using my programmer, but I do not know much about laptop motherboards, and was wondering if someone could help me.
                                          Firstly, is...
                                          Yesterday, 03:33 PM
                                          09-06-2024, 06:06 AM
