Bdl50 la-0704p dead
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 346
    • India
    Bdl50 la-0704p dead
    Hi
    la-704p board is dead ,
    19 volts ok .
    No 3.3. or 5 volts
    Coil (LP 602 ) Shows 0 Ohms Reading ,after opening 1 side of coil , towards CPU SAME value 0 Ohms.
    is CPU SHORT ?
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 346
    • India
    Re: Bdl50 la-0704p dead
    No one to reply ..
    • zpi
      • Feb 2018
      • 132
      • Lithuania
      Probably, check on google usual ohms to ground on this cpu. Also hoe many ohms to ground.on 3.3v and 5v?
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 346
        • India
        Update .. Coil PL9 (3R3) also showing 0 ohms ref to ground,after opening PJP2 .Coil side ok .
        • sopik78
          • Nov 2013
          • 517
          • Czech Republic
          If you have 0 ohms to CPU side, CPU is definitely shorted. Just test it with power on coil if CPU is getting hot.
          • zpi
            • Feb 2018
            • 132
            • Lithuania
            0ohms does not indicate bad cpu, need to compare with working cpus. Some of CPUS has very low ohms to ground on vcore.
            • piernov
              • Jan 2016
              • 4437
              • France
              Skylake is typically around 6 ohms to ground on CPU VCore.
              • ravi_1617
                YY Solutions
                • Jan 2012
                • 346
                • India
                Just Resistance reading
                • ravi_1617
                  YY Solutions
                  • Jan 2012
                  • 346
                  • India
                  Injected power nothing heating .
                  Around 1 to 1.3 volt consumes 0.67 to 0.75 Amps maximum
                  • tahc81
                    • Nov 2019
                    • 42
                    • Slovakia
                    Hi, having the same board on a desk (i5-6200U), with same issue. Let's inject more amps, I've used ~3A to have ~4W for dissipation, then you can identify source easily. In my case it's smaller die on a CPU package. Strange that is probably third board with 6th Gen Intel with same issue.
                    EDIT: also have short on +1.0V_PRIM rail
                    • RichBon
                      • Apr 2019
                      • 54
                      • Ghana
                      i am also having the same board but it shutdown with the information cool system but the fan works well i have change fan and heat sink still the same. the ec pin 26 gives me 1.47v
                      • MisterAIL
                        PS5 digital / No Power / No Beep / Good power supply
                        by MisterAIL
                        Brought a non functionnal PS5. Apparently only a bad PSU...
                        No beep, nothing.
                        After some tests i found this :
                        - PSU is fine (12 volts stable)
                        - 12 volts line is shorted
                        - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                        - By the way, nothing change. No signal, no power, no beep.
                        Mesuring all rails with my workbench psu (12 volts input)
                        - 0.00 amp drawing
                        - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                        03-12-2024, 03:24 PM
                      • BTubbs200
                        Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                        by BTubbs200
                        Dell Latitude 5420 P137G
                        Board: LA-K491P REV A01
                        I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                        Board seems to have no shorts, all power rails are fine and show high resistance.
                        When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                        01-24-2025, 08:15 PM
                      • Nagyesz
                        Lenovo ideapad 330ICH - Dead, no volts on coils
                        by Nagyesz
                        Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                        I've never encountered something like this before;
                        No charging light, full dead
                        Lenovo Ideapad 330-17ICH
                        • PL3102: 5 ohms
                        • PL3001: 3.2 ohms
                        • PL3101: 2 ohms
                        • PL5801: 3.5 ohms
                        • PL5501: 270 ohms
                        • PL701: 35 ohms
                        • PL501: 146 ohms
                        • PL503: 390 ohms
                        • PL402: OL (0.27V) +5VALW_P
                        • PL301: OL
                        • PL401: OL (0.03V) +3VALW_P
                        + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                        10-11-2024, 10:12 AM
                      • Ghostalker
                        Zephyrus G14 GA401QM dead
                        by Ghostalker
                        Hello I have an ASUS Zephyrus Laptop (Model GA401QM), bought on ebay and the previous owner claims he was using and the laptop stopped, He then tried to change battery and broke the connector on the battery and also on ripped a GND pad on the MB.
                        I was searching on internet and found two posts on this forum about a similar problem “ASUS ROG G14 (GA401) battery spark, dead.” and “Dead ASUS ROG G14 (GA401)” both by the user jacobtc.
                        I already made some measurements based on the “Dead ASUS ROG G14 (GA401)” post using GA401QM schematic provided here and Boardview provided...
                        09-06-2023, 03:20 PM
                      • BalkanBoy
                        Dead Razer Blade 14 2022, shorted CPU?
                        by BalkanBoy
                        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                        I removed coil and injected 0.7V, it draw around...
                        09-27-2024, 12:44 PM
