No Power CG420 NM-A805 REV 1.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Having issue on this board low impedance on pl1 those these normal?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: No Power CG420 NM-A805 REV 1.0
    I tried to remove the PL1 testing pin 1 no short pin 2 has short I tried to remove the caps connected to pl1 still shorted in pj20
    • Sephir0th
      • Oct 2020
      • 1282
      You are Not new Here but so much Threads still with less informations shared.
      Exact Resistance to ground in Ohms Please. What is the actual issue of the laptoo? What is the History?
      FairRepair on YouTube
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        the pj20 has 7 ohms the board history was no power sir
        • Sephir0th
          • Oct 2020
          • 1282
          Can be normal. Let's check other things first. Do you have 19V, +3VALW and +5VALW? EC gets his voltage (+3VL)?
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            19v present +3valw no and +5ALW no
            Checking pins of PU911 OZ8682LN_QFN16_3X3
            PIN 1 - 0V
            PIN 2 - 19V
            PIN 3- 19V
            PIN 4- 19V
            PIN 5- 19V
            PIN 6 0V
            PIN 7- 0V
            PIN 8 - 0V
            PIN 9 -0V
            PIN 10 0V
            PIN 11- 0V
            PIN 12 -19V
            PIN 13- 19V
            PIN 14- 19V
            PIN 15- 0V
            PIN 16 -0V
            PL710 19V
            • Sephir0th
              • Oct 2020
              • 1282
              Check Diode PD706 for voltage on both sides. if you have 19V on one side but no voltage on the other side, check Ohms to ground on both sides. If no short, replace the Diode PD706.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                no voltage left and right also the pd303 resistance to ground of pd706 pin 1 has no resitance pin 2 has 335 kiloohms pin 1 has 19v pin 2 0v
                • khaahk
                  • Dec 2013
                  • 766
                  • Estonia
                  If you have 19V on pu401, then you should have +3VLP output. If not check for low resistance and if not, then replace PU401. 7 ohms on 1.05V rail seems little too low.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    the reisistance of PL1 sir is 4 ohms to ground
                    • khaahk
                      • Dec 2013
                      • 766
                      • Estonia
                      First things first: do you have the +3VLP on pin 17 of PU401?
                      • paulo66
                        • Dec 2020
                        • 88
                        • Portugal
                        Hello, I´m new here and I have to post to be able to start a thread.
                        Re: no +3alw and no +5valw... It´s weird that sometime, after messing around, on my mb there is +3.3v at the power button but no voltages are present on pl401 and pl402 nor on pin 8 of the bios chip.
                        To fix this I have to follow these exact steps:
                        1. remove main battery, cmos battery, power adapter from the mb end and from the mains as well (or else no 20vdc on the charging port at times).
                        2. short the cmos socket pins.
                        3. plug the adapter in the mains first, then to charging port.
                        the +3alw and the +5alw should now be present at the coils. If not, repeat step 2 and short the pins for a bit longer. Press the novo switch to help discharge any residual voltages left.
                        Hope this helps.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
