ASUS UX360UA Turns On No Image
  • CohenC
    • Oct 2020
    • 8
    Hiya,
    I'm trying to delve into the world of electronics repair, this forum has been of great help in my research to date, but today I am here with a question of my own.
    I've been given an ASUS UX360UA to work on, the laptop powers on and charges, the keyboard 'lock' keys respond correctly and the USB port receives power, however, the OS does not seem to load up as I get no HDMI output or sound when I plug in the USB. I also see no obvious thermal mass through a Seek CompactPro.
    I've taken measurements off of the motherboard and found that one of the coils near the CPU reads zero voltage and is shorted to ground, along with all of the capacitors nearby.
    Being an ASUS there are no schematics or board view available and this is my first time working on a laptop without them; I'm a bit unsure of where to look next, the board has almost no traces on the top and the entire bottom of the board is just traces.
    Any pointers would be much appreciated
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: ASUS UX360UA Turns On No Image
    Seems bios issue as no Volt on pin 5,6
    If you have oscilloscope
    Check pin 5,6
    Flash a good known bios
    Core coil will always show short to ground as less ohm
    Resistance
    • CohenC
      • Oct 2020
      • 8
      Thanks for your response.
      I had read about certain rails always shorting to ground, but it's nice to see it in practice
      I don't have one, however, this is now a good reason to get one, it's been on my bucket list for a while.
      I will attempt to flash the BIOS and get back to you!
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        how much is the resistance to GND on the 0-volt coil?
        • piernov
          • Jan 2016
          • 4439
          • France
          If caps lock key triggers caps lock LED it typically means it's POSTing correctly. Check if it does the same with external keyboard.
          Also what about image/backlight on internal display?
          • CohenC
            • Oct 2020
            • 8
            9.5-10 Ohms
            That's what I came to believe as well, but would it be common for a BIOS chip to have 0-volt pins?
            Nothing on the internal display and many 0 volt pins on the connectors connecting the screen as well; yeah the LEDs on an external keyboard do respond to lock keys.
            I'm assuming the 0V coil is which is closest to the SSD powers that, would I be correct in assuming this likely won't be activated until it is called for by the BIOS?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              Disconnect the internal display and HDD, then test HDMI.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                If external keyboard is working then it is indeed not a bios issue but bios chip pin ,1,2,5,6 should have voltage fluctuating or stable as frequency signals
                Maybe different bios chip
                Do as suggested above
                Hmm interesting
                • CohenC
                  • Oct 2020
                  • 8
                  No dice, same result. The display connectors have multiple 0 volt pins as well.
                  Hmm interesting
                  Have ordered a programmer, will arrive in a couple weeks I hope.
                  In the meantime, I monitored pins 5 and 6 during the boot cycle and they DO indeed fluctuate for the first 10 or so seconds before stabilising at 0V afterwards; pins 1 and 2 remain largely stable.
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    Now, more tests have to be done on this laptop to find more clues. such as DVD drive and HDD activity.
                      ASUS ZenBook UX360UA-DQ008T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX360UA-DQ008T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX360UA-DQ008T boardview and UX360UA-DQ008T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 05:59 AM
                      ASUS ZenBook UX360UA-AS78T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX360UA-AS78T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX360UA-AS78T boardview and UX360UA-AS78T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 05:46 AM
                    • waakye
                      ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                      by waakye
                      I was giving this ASUS ROG G750JM that exhibit the following behavior:
                      When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                      My issue is the laptop doesn't stay on for a long time and turn itself off.
                      Any lead on how to resolve this will be appreciated.
                      I cannot boot in windows and no liquid damage.
                      Thanks in advance.
                      09-13-2024, 08:10 PM
                    • andrhouseolly
                      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                      by andrhouseolly
                      Hi.
                      I kindly ask you to help me solve the problem.
                      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                      The board turns on, there is no image.
                      Read more. When the power supply is connected, the front panel indicators light up briefly.
                      When you press the power button, the button indicator lights up. The board works
                      there is no image, there is no matrix initialization, there is no image on HDMI.
                      When turned on, the fans do not spin, but when they warm up they start spinning.
                      When you turn off the button, the fans spin up to full speed for a short...
                      05-11-2024, 03:14 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
