a1989 820-00850-a no power
  • Harryrepair
    • Jul 2016
    • 71
    Hello all,
    this board is drawing 0.00 - 0.13a (jumping) with 20.3V
    I assume all cd3215 are ok.
    U6940 has 3.3v on pins 1,3,4 but 0.00 v on pin 10 (chgr_rst_in_r)
    By the way L7600 is showing 0.03v,pp5v_g3s is missing.
    U7000 was already treated (picture below)
    Thank you in advance!
  • Harryrepair
    • Jul 2016
    • 71
    Re: a1989 820-00850-a no power
    Hello all,
    i measured all Power Rails. there is a lot of missing and PPBUS should be at 13.1V i think.
    It looks like PP5v_G3S is not created, the Enable Signal is 0V as well.
    The device can be put into DFU Mode but the repair aborts.
    Any ideas?
    PBUS_G3H 12.26 V
    PPBUS_HS_CPU 12.27 V
    PPVIN_G3H_P5VG3S 12.27 V
    PPVIN_G3H_P3V3G3H 12.27 V
    PPVIN_G3H_P3V3G3HRTC 12.27 V
    PPBUS_G3H_SSD0 12.27 V
    PPBUS_G3H_SPKRAMP_LEFT 12.27 V
    PPBUS_G3H_SPKRAMP_RIGHT 12.27 V
    PPDCIN_G3H 20.3 V
    5V Rails
    PP5V_G3S 0.009 V
    PP5V_G3S_CPUREG 0.009 V
    PP5V_G3S_TPAD 0V
    PP5V_G3S_KBD 0V
    PP5V_G3S_ALSCAM 0 V
    PP5V_S4SW 0 V
    PP5V_S4SW_ISNS 0 V
    PP5V_S0SW_LCD_ISNS_R 0.07 V
    PP5V_S0SW_LCD 0.4 V
    PP5V_S5_LDO 0 V
    3V3 Rails
    PP3V3_G3H_RTC 3.39 V
    PP3V3_G3H_SSD0 3.39 V
    PP3V3_G3H_RTC_MESA 3.39 V
    PP3V3_G3H 3.33 V, jumps all 5sec. for a mom to 2.3V
    PP3V3_G3H_PMU_VDDMAIN same as above
    PP3V3_G3H_DFR same as above
    PP3V3_S4SW_SNS 0 V
    PP3V3_G3S 0 V
    PP3V3_S0_TBT_X_ISNS_R 0V
    PP3V3_TBT_X_S0 0V
    PP3V3_S0_TBT_T_ISNS_R 0V
    PP3V3_TBT_T_S0 0V
    PP3V3_G3S_WLANBT 0V
    PP3V3_G3S_TPAD 0V
    PP3V3_G3S_KBD 0V
    CPU/PCH Rails
    PPVCC_S0_CPU 0V
    PPVCCSA_S0_CPU 0 V
    PPVCCGT_S0_CPU 0V
    PPVCCEDRAM_S0_CPU 0V
    PPVCCIO_S0_CPU 0V
    PP1V2_S0SW 0V
    1V8 Rails
    PP1V8_G3S 0V
    PP1V8_G3S_WLANBT_VDDIO 0V
    Memory Rails
    PP1V2_S3 0V
    PP1V2_S3_CPUDDR 0V
    PP0V6_S0_DDRVTT 0V
    PP0V6_S3_MEM_VREFDQ_A 0V
    PP0V6_S3_MEM_VREFCA_A 0V
    PP0V6_S3_MEM_VREFDQ_B 0V
      MSI Gaming GL72M 7RDX 1227 Notebook GL Specification for Upgrade or Repair
      This specification for the MSI Gaming GL72M 7RDX 1227 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL72M 7RDX 1227 boardview and GL72M 7RDX 1227 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
      09-06-2024, 06:51 AM
    • Nikan.e
      MacBook A1989 missing rails PP3V3_S5 and PP1V8_S5
      by Nikan.e
      Greetings and Salutations,
      I have gotten an A1989 Macbook board number 820-00850-A which has two missing rails -> PP3V3_S5 and PP1V8_S5.
      PBUS is at 12.6V every other voltage made by the PMIC is just fine.
      Resistance to ground -> PP3V3_S5 ~ 220Ω
      Resistance to ground -> PP1V8_S5 ~ 220Ω
      PP1V8_S5 and PP3V3_S5 are not shorted together.
      Voltages up to PP2V5_NAND_SSD0 seem to be fine.
      Can anyone confirm if these resistances are normal for this board?
      What could be causing this issue?
      Is there a way to...
      12-04-2023, 03:44 AM
    • skwarszczow
      Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
      by skwarszczow
      This is my first post on the forum
      I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
      Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
      Before completing the purchase, we decided to erase...
      03-23-2025, 06:04 PM
    • gugutm
      a1989 820-00850 stuck at 5v 0.041a Help
      by gugutm
      I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
      long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
      of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
      01-04-2025, 09:35 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
