ACER ES1-311 battery not charging
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day to all , I have a issue of this model Ive change already the battery but it wont charge those anyone has a schematic diagram also for this model?
    LAW_BA MB 14295-1M448.05T02.001M
    <a href="https://ibb.co/1RS69jH"><img src="https://i.ibb.co/1RS69jH/NBMZU11002-Motherboard-for-Acer-Aspire-ES1-331-LAW-BA-448-05-T02-001-M-jpg-q50.jpg" alt="NBMZU11002-Motherboard-for-Acer-Aspire-ES1-331-LAW-BA-448-05-T02-001-M-jpg-q50" border="0"></a>
    BAT1 connection (withput the battery)
    PIN 1/2 has 2.7v
    pin3 0v
    pin4 3.2v
    pin5 3.2v
    pin6 3.2v
    pin7/8 has ov
    with the battery connected
    pin1/2 has 2.7v
    pin3 0v
    pin5 3.2v
    pin 6 3.2v
    pin78 has 0v
    i dont have any schematics thats why its hard to troubleshoot
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: ACER ES1-311 battery not charging
    Known good battery? Battery disable switch?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes ithough I have abad vbattery but because of theswitch
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DenK
        Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
        by DenK
        Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
        1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
        12-06-2024, 01:29 AM
      • survivalbloke
        Acer Predator Helios 300 - will not power up if battery is CONNECTED
        by survivalbloke
        This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
        06-25-2025, 12:20 PM
      • ahmarzo
        Acer TMX314-51 laptop battery problem
        by ahmarzo
        I have acer laptop tmx314-51 with part no 6050A3020501.
        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
        The schematic is not available...
        04-11-2025, 09:14 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
