820-4924 Jack stuck inside
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Hi guys , i have this macbook with broken jack stuck in , customer doesnt want to replace the jack .
    I want to disable the jack , i removed l6607 l6608 and l6604 , now is stuck in digital out ..
    TO avoid removing completely the jack , any way to disable the jack and use only internal speaker ?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: 820-4924 Jack stuck inside
    maybe do it with an audio mixer . i know i can do things like that with my pc .
    • piernov
      • Jan 2016
      • 4439
      • France
      Try removing L6606 maybe
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        Removed stilo spdif , removed the jack whole . Stile in spdif
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • Flaku_34
          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
          by Flaku_34
          Introduction:
          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
          04-18-2024, 12:47 PM
        • valvashon
          Samsung UN55FH6030CXZA main board USB jack indentification
          by valvashon
          Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
          I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
          01-23-2025, 11:17 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • brotank
          Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
          by brotank
          I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
          can someone disable onboard ram from my dumped bios, please 🙏
          I tried the other bios on this forum with disabled onboard ram, but no success
          my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
          after that I officially give up 😂
          thanks for awesome jobs 😊...
          03-16-2025, 12:51 PM
