Help Gigabyte GA-RX7X7 in a Auros X7
  • luckydip
    • Aug 2016
    • 165
    Hi Guys
    This arrived dead and it looks like someones had a go at this. Working blind as I don't have boardiew/schematics. So far when I press the power button, 19v present, 3.3v on coil and on bios.
    Should I be looking to restore 5V next? Any idea if it should be on the coil next to the 3.3V coil? Currently 0v no short.
    Any other ideas wecome.
    thanks
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Help Gigabyte GA-RX7X7 in a Auros X7
    You can check voltage on all coils and without power impedance of coils. All should be above 300 ohm except three CPU,GPU and vccio and ram coil
    Without power
    Use beep or continuity mode of multimeter to check short of first two MOSFETs and voltage on gate of 2nd mosfet
    Pin 1,2,3, source
    Pin 4 gate
    5,6,7,8 drain
    If liquid damage then it must be cleaned first
    Mostly GPU area is effected
      • 21895
      Originally posted by luckydip
      Hi Guys
      thanks
      Post the part numbers of all the QFN chips on the board.
      • luckydip
        • Aug 2016
        • 165
        These are the ones I can identify:
        BQ24780 charger IC
        Asm1061 sata driver
        UP9511p gpu power
        Sic631 driver
        95855 multiphase vcore
        75dp159 HDMI
        Tps65982 USB/C
        Rts5328 controller
        • DynaxSC
          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
          by DynaxSC
          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
          General test conditions:
          - Tested with Core i5 6500 and Core I7 6700K - no difference
          - Default BIOS settings, but tried also altering several memory setting - does not change anything
          What is wrong:
          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
          03-21-2025, 06:23 PM
          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
          by momaka
          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
          And a shot of the label:...
          01-26-2022, 03:26 AM
          Thermal pad thickness for various laptop GPU / Graphics Cards
          ASUS Dual RTX 2070 OC 8GB
          ASUS ROG STRIX RTX 3080 OC
          ASUS ROG STRIX RTX 3090
          ASUS TUF Gaming RTX 3080 OC Edition
          ASUS TUF GTX 1660 S-O6G GAMING
          EVGA RTX 3060 Ti XC GAMING 8GB
          EVGA RTX 3060 XC GAMING 12GB GDDR6
          EVGA RTX 3080 FTW3 ULTRA GAMING
          EVGA RTX 3080 TI FTW3 ULTRA GAMING
          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
          Gainward RTX 2080 Phoenix GS Specs
          Gainward RTX 3070 Phoenix 8GB
          Gainward RTX 3080 Ti Phoenix
          GIGABYTE AORUS RTX 3080 MASTER 10G
          02-09-2024, 08:08 AM
        • nikovmiroslav
          Gigabyte A5 X1 Need Bios
          by nikovmiroslav
          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
          Gigabyte A5 X1
          From motherboard:
          S/N: 1TNH55ER1350895
          P/N: 6-77-NH55ERQY-D02-2CGB
          On sticker from the back of the laptop:
          S/N: SN21351J000657...
          08-24-2025, 09:15 AM
          Gigabyte AORUS 15 Notebook Specification for Upgrade or Repair
          This specification for the Gigabyte AORUS 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 boardview and 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15 Notebook...
          09-07-2024, 07:19 AM
