lenovo ideapad 110 power button>>>
  • salmanzeiad
    • May 2016
    • 68
    • world
    How do I find two operating points from the board without using the keyboard
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenovo ideapad 110 power button>>>
    On keyboard connector . What is the mb code??
    • Dr.d
      Help please..Lenovo ideapad 5 14itl05 power and charging problem
      by Dr.d
      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
      04-05-2024, 11:48 AM
    • rabsonnjala
      LENOVO IDEAPAD 100 works only on bench power supply
      by rabsonnjala
      Hie I have a Lenovo laptop
      Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
      it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
      below are my readings
      with the original charger only
      JBATT1
      PIN1 0.22V
      PIN2 0.22V
      PIN3 0.45V
      PIN4 0.45V
      PIN5 O.43V
      PIN6 0V
      PIN7 GND
      PIN8...
      11-20-2021, 08:32 AM
    • acata
      Lenovo Ideapad slim 3 not power on
      by acata
      Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
      And the consumer asked for reinstalling OS.
      I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
      Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
      Check the main power rail for 20v input ok
      No amper input from Power supply 0.013a
      Mosfet PQ201 20v and 26v ok.
      3.3v exist
      1,8v exist
      5v exist
      12v from baterai exist....
      09-30-2024, 09:42 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
