Hp la-d704
  • bakre
    • Dec 2014
    • 105
    • Zwolle
    Hp la-d704
    Hello gays
    I have an HP 15 with mainboard LA-D704 is not turn on at all.
    19v in is present
    Acok is 3,3v
    Acdet is 2.5v
    ADP_ID is 1.75v
    EC_ACIN is 3.2V
    VCIN0_PH is 2,7v
    EC_RST# is 3.25V
    in the schematic it should give EC_ON to start the 5/3v always to start all the section but it not giving this signal unfortunately this line is not shorted to ground i have replace the i\O and the charging IC and 5/3v no change.
    i thing i have one missing signal on i/o chip if any one can give an idea to solve the problem.
    it is an HP 15-ay094nd reflash the bios also no change, if any one have an EC dump i can try to reflash it maybe will help.
    When insert the battery is charging and it light orange.
    Thanks. any idea
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp la-d704
    Check your dc jack or better replace it.
    • bakre
      • Dec 2014
      • 105
      • Zwolle
      Re: Hp la-d704
      Thanks for answer
      The problem solve with reprogram the i\o chip
      • tigertec
        HP Laptop 15-dy****** BIOS Reflash
        by tigertec
        Hello all, I am pretty sure my BIOS is corrupt and I need to reflash. I have the chip desoldered and ready to go, however, I can't seem to find the file to do so. I was curious if y'all can point me in the right direction or perhaps provide the file.
        Thanks!
        Model 15-DY4013DX
        Serial 5CD244G3LS
        06-23-2025, 12:47 PM
      • Addster09
        Get the name for BIOS reflash on Lenovo ThinkPad 13 Gen 2 (20J2)
        by Addster09
        Hello fellow humans!
        I was updating my BIOS and then the power cut out and the laptop turned off and after that it only turns on the light on the lenovo logo and the fans spin up (the screen remains black). After some research I found that ThinkPads support a feature called a BIOS reflash or BIOS flashback but it isn't very well documented. I also read in a post that a specific name is required for a flashback to start so can anyone tell me how to get the recovery file name for a BIOS reflash for my Laptop?
        Any help will be appreciated!
        10-11-2023, 01:19 AM
      • etnkcxs
        dell latitude 3410 does not save service tag after reflash bios
        by etnkcxs
        Hello everyone!
        I am new to the forum, and could use some help.
        I reflash the BIOS of a Dell Latitude 3410 16MB + 8MB with a CLEAR ME bin.
        After that the notebook starts in manufactiring mode and does not save the Service Tag in the BIOS.
        If I can HEX edit the BIOS and reflash the BIOS again I would like to be taught.
        Thanks in advance
        03-29-2023, 06:57 AM
      • ktmmotocross
        need identify emmc chip and point how to reflash it
        by ktmmotocross
        Hello.
        Have this ic emmc from some TV. i need to identify it and point how to reflash it, with cheap programmer....
        08-06-2023, 04:45 AM
      • pingaroon
        HP EliteBook 835 G9 corrupted SIO - how to reflash?
        by pingaroon
        Serial: 5CG2271DC5
        Hello folks, have an 835 G9 Laptop, which started with keyboard lighting up, but black screen, no further. Tried changing the 2 bios chips (both 32MB WSON) with multiple various dumps but no result (coudn't find any 835 G9 dumps, but 845 G9 and 865 G9 use the same bios according to HP) Board voltages all appear normal. Long-pressing the power button has no effect, so suspect corrupt contents of the SIO (NPCX998HA0BX), assuming the chip itself is good. So, how to reprogram? Would soldering on a blank replacement self-program (assuming original bios chip contents...
        05-22-2025, 07:56 AM
