HP EliteBook 835 G9 corrupted SIO - how to reflash?
  • pingaroon
    • Nov 2019
    • 121
    • uk
    Serial: 5CG2271DC5
    Hello folks, have an 835 G9 Laptop, which started with keyboard lighting up, but black screen, no further. Tried changing the 2 bios chips (both 32MB WSON) with multiple various dumps but no result (coudn't find any 835 G9 dumps, but 845 G9 and 865 G9 use the same bios according to HP) Board voltages all appear normal. Long-pressing the power button has no effect, so suspect corrupt contents of the SIO (NPCX998HA0BX), assuming the chip itself is good. So, how to reprogram? Would soldering on a blank replacement self-program (assuming original bios chip contents are back on the board), or would modding the contents of the main bios chip to put it in mpm mode enable the existing SIO to be reprogrammed? Trying to avoid having to remove the SIO if at all possible. Have attached the original main bios and ec bios dumps. Any help appreciated. Thanks.
  • peste
    • 13122
    • ROMANIA
    Originally posted by pingaroon
    Serial: 5CG2271DC5
    The SIO chip can only be programmed when it is empty and at the first start....either erase the contents of the SIO chip with a programmer, or change the SIO chip with a new one...remember...not all HP models have the chip programmed itself......ideally you would have an adapter for the chip and programmer, write the new external chip in the adapter then solder the chip...as a last resort if you can't find a bios for this laptop model you can try with a new chip to see if it writes it...don't forget to make a copy of the SIO chip before writing....I don't know if this chip can be written with the programmer via the keyboard...
    • pingaroon
      • Nov 2019
      • 121
      • uk
      Thanks peste . It's a pesky BGA SIO, so I don't have the equipment to program it externally. I have a Successor programmer and a TL866II+ but there is no record of anyone programming a NPCX998HA0BX either through the keyboard connector, or via JTAG (and the absence of any schematic stops the possibility of programming via JTAG). I'll reflash the original bios chips and put a new, empty NPCX998HA0BX chip on and see if it manages to self-program... Will report back once the chip arrives from China...
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • Azurain
        Elitebook 840 G5 Bios Chip Soldering Question
        by Azurain
        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
        04-14-2023, 06:58 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
        HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
        This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
        09-07-2024, 05:50 AM
